メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iBUYPOWER Y40 IBP Thermal Paste Replacement
必要な工具と部品
  1. iBUYPOWER Y40 IBP Thermal Paste Replacement, Thermal Paste: 手順 1、 1の画像 1
    • Shut down the computer completely and unplug the power cable before opening the case.
    • Allow the system to cool for several minutes before you begin the repair.
    • Never work inside the computer while it is still connected to power.
    FixBotに聞いてみる
    コメントを追加
  2. iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 2、 3の画像 1 iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 2、 3の画像 2 iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 2、 3の画像 3
    • Carefully remove the tempered glass side panel to access the internal components of the desktop.
    • Place the panel somewhere safe to avoid scratches or damage.
    • Handle the glass panel carefully to prevent breakage or scratches.
    • Identify the CPU cooler mounted on top of the processor. It must be removed to access the processor and replace the thermal paste.
    • In this system, a liquid CPU cooler is installed with a pump block connected to the radiator.
    FixBotに聞いてみる
    コメントを追加
  3. iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 3、 1の画像 1
    • Use a Phillips #0 screwdriver to loosen the CPU cooler screws in a cross pattern, loosening each screw gradually to avoid uneven pressure.
    FixBotに聞いてみる
    コメントを追加
  4. iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 4、 1の画像 1
    • Gently lift the CPU cooler straight out from the processor.
    • If it feels stuck, slightly twist it to break the seal of the old thermal paste before lifting.
    • Do not touch the surface of the CPU with your fingers, as oils from your skin can affect performance.
    FixBotに聞いてみる
    コメントを追加
  5. iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 5、 1の画像 1
    • Apply a small amount of 90% isopropyl alcohol to a microfiber cloth and gently wipe the old thermal paste from both the CPU and the bottom of the cooler.
    • Continue cleaning until both surfaces are completely clean and dry.
    • Apply a pea-sized amount of new thermal paste to the center of the CPU.
    FixBotに聞いてみる
    コメントを追加
  6. iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 6、 1の画像 1
    • Place the CPU cooler back over the processor and align it with the mounting holes.
    • Tighten the screws evenly to secure the CPU cooler in place.
    • Check that the CPU cooler is properly seated and all screws are tightened securely.
    FixBotに聞いてみる
    コメントを追加
  7. iBUYPOWER Y40 IBP Thermal Paste Replacement: 手順 7、 1の画像 1
    • Reconnect the power cable, close the case, and power on the system.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Jaylen Emanuel
メンバー登録日: 02/27/26
145 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team A-7, Serna Spring 2026 Austin Community College, Team A-7, Serna Spring 2026人のメンバー
AUSTINCC-SERNA-S26SAG7
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 74
