はじめに
Replacing the cameras that may be cracked or faulty on your Zeki Droid Tablet. This procedure should take no more then twenty minutes to complete. The process will include using tools such as spudgers, and tweezers.
必要な工具と部品
Remove the back casing by slowly popping each tab out with a plastic opening tool.
この手順で使用する道具:Tweezers$4.99
Grip the camera on both sides using tweezers or your fingers, and carefully lift it off the board.
ある他の人がこのガイドを完成しました。
