メインコンテンツにスキップ
Xiaomi Mi Watch 2021 Battery Replacement
必要な工具と部品
  1. Xiaomi Mi Watch 2021 Battery Replacement, Unfasten the screws: 手順 1、 1の画像 1
    • Opening the Mi Watch will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your watch without replacing the seals.
    • Before starting the disassembly, turn off your watch.
    • Remove the four 3.2 mm-long T3 Torx screws on the back of the watch.
    • A T3 screwdriver has a tight fit on these screws and might require a bit more downward pressure to unfasten the screws. A T2 fits as well but poses the risk to strip the screw heads.
  2. Xiaomi Mi Watch 2021 Battery Replacement, Create a small gap: 手順 2、 3の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Create a small gap: 手順 2、 3の画像 2 Xiaomi Mi Watch 2021 Battery Replacement, Create a small gap: 手順 2、 3の画像 3
    • Insert the flat end of a spudger into the loudspeaker opening at the top edge of the rear case assembly.
    • Push the spudger upwards to create a small gap between the rear case assembly and the watch housing.
  3. Xiaomi Mi Watch 2021 Battery Replacement, Pry up the rear case: 手順 3、 2の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Pry up the rear case: 手順 3、 2の画像 2
    • Insert your spudger into the gap and pry up the rear case assembly.
    • Only work with the edge of your spudger and do not insert it deeper than 3 mm.
    • Steady the rear case assembly with a finger to prevent it from suddenly popping open and damaging the flex cable.
    • Don’t try to remove the rear case assembly all the way yet. It is still connected to the motherboard with a thin flex cable.
  4. Xiaomi Mi Watch 2021 Battery Replacement, Open the watch assembly: 手順 4、 2の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Open the watch assembly: 手順 4、 2の画像 2
    • Carefully swing open the rear case assembly by folding the rear case to the side with the watch buttons.
    • Avoid straining the flex cable during this procedure.
  5. Xiaomi Mi Watch 2021 Battery Replacement, Unfasten the screw: 手順 5、 1の画像 1
    • While it's possible to remove the battery without disconnecting the rear case assembly first (jump straight to step 8), there's a substantial risk of damaging components. We highly recommend removing the rear case assembly.
    • Remove the 2.7 mm-long Phillips screw securing the metal bracket.
  6. Xiaomi Mi Watch 2021 Battery Replacement, Remove the metal bracket: 手順 6、 2の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Remove the metal bracket: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
  7. Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the rear case assembly: 手順 7、 2の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the rear case assembly: 手順 7、 2の画像 2
    • Use the flat end of a spudger to pry up and disconnect the rear case assembly connector from the motherboard.
  8. Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the battery: 手順 8、 2の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Disconnect the battery: 手順 8、 2の画像 2
    • Use the flat end of a spudger to pry up and disconnect the battery connector.
  9. Xiaomi Mi Watch 2021 Battery Replacement, Pry up the battery: 手順 9、 3の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Pry up the battery: 手順 9、 3の画像 2 Xiaomi Mi Watch 2021 Battery Replacement, Pry up the battery: 手順 9、 3の画像 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert an opening pick underneath the left edge of the battery.
    • Tilt down your opening pick to pry up the battery.
  10. Xiaomi Mi Watch 2021 Battery Replacement, Remove the battery: 手順 10、 2の画像 1 Xiaomi Mi Watch 2021 Battery Replacement, Remove the battery: 手順 10、 2の画像 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
終わりに
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
210,138 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
17,899のガイドは作成済み
2 件のコメント
Hi,
I have the s1 active and the battery connector is broken so it can't charge the watch.
Can you please suggest some store to buy online the battery connector and the battery to replacement?
leftkoyl - 返信
hi,
where can i purchase the metal bezel/case replacement for S1 active? thanks
Fizul Khairi - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 63
過去 30 日: 305
今までの合計 6,873
