メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wacom Intuos Pro Battery Replacement
必要な工具と部品
  1. Wacom Intuos Pro Battery Replacement, Battery: 手順 1、 3の画像 1 Wacom Intuos Pro Battery Replacement, Battery: 手順 1、 3の画像 2 Wacom Intuos Pro Battery Replacement, Battery: 手順 1、 3の画像 3
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
    FixBotに聞いてみる
    コメントを追加
  2. Wacom Intuos Pro Battery Replacement: 手順 2、 3の画像 1 Wacom Intuos Pro Battery Replacement: 手順 2、 3の画像 2 Wacom Intuos Pro Battery Replacement: 手順 2、 3の画像 3
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
    • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
    FixBotに聞いてみる
    コメントを追加
  3. Wacom Intuos Pro Battery Replacement: 手順 3、 2の画像 1 Wacom Intuos Pro Battery Replacement: 手順 3、 2の画像 2
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
    FixBotに聞いてみる
    コメントを追加
  4. Wacom Intuos Pro Battery Replacement: 手順 4、 2の画像 1 Wacom Intuos Pro Battery Replacement: 手順 4、 2の画像 2
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
    FixBotに聞いてみる
    コメントを追加
  5. Wacom Intuos Pro Battery Replacement: 手順 5、 2の画像 1 Wacom Intuos Pro Battery Replacement: 手順 5、 2の画像 2
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
chris peterson
メンバー登録日: 01/22/20
233 ポイント
1ガイドが承認済み
7件のガイドコメント
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - 返信 共有
Do you know where can I find the battery replacement?
Valerio _ - 返信 共有
Has anyone got a lint to the replacement battery?
Luca Di Meo - 返信 共有
PTH-660 works fine without the battery, just remove it and use it with USB cable
Luca Di Meo - 返信 共有
Where can I find a replacement battery for this model?
Denise Hanly - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 27
過去 30 日: 176
今までの合計 11,675
