メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
VTech Little Apps Tablet Speaker Replacement
必要な工具と部品
    1. VTech Little Apps Tablet Speaker Replacement, Battery: 手順 1、 1の画像 1
      • Remove the 9.9 mm screw covering the batteries with a PH1 driver head.
      FixBotに聞いてみる
      コメントを追加
    2. VTech Little Apps Tablet Speaker Replacement: 手順 2、 1の画像 1
      • Use a plastic opening tool to pry the batteries out of their holding.
      • If replacing your batteries with new ones, be careful to insert them as indicated on the device.
      FixBotに聞いてみる
      コメントを追加
    1. VTech Little Apps Tablet Speaker Replacement, Back Cover: 手順 3、 2の画像 1 VTech Little Apps Tablet Speaker Replacement, Back Cover: 手順 3、 2の画像 2
      • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
      • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
      FixBotに聞いてみる
      コメントを追加
    2. VTech Little Apps Tablet Speaker Replacement: 手順 4、 2の画像 1 VTech Little Apps Tablet Speaker Replacement: 手順 4、 2の画像 2
      • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
      • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
      FixBotに聞いてみる
      コメントを追加
    1. VTech Little Apps Tablet Speaker Replacement, Speaker: 手順 5、 2の画像 1 VTech Little Apps Tablet Speaker Replacement, Speaker: 手順 5、 2の画像 2
      • The speaker should be located at the bottom-right side of the back cover from your perspective.
      • Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
      • Be careful not to disturb the wires while removing the screws.
      FixBotに聞いてみる
      コメントを追加
    2. VTech Little Apps Tablet Speaker Replacement: 手順 6、 2の画像 1 VTech Little Apps Tablet Speaker Replacement: 手順 6、 2の画像 2
      • Remove the speaker from its holding and place it to the side of the device.
      • Desolder the brown wires from the speaker connections.
      • Soldering is the most difficult step in this guide. If you are in need of assistance with this step, refer to this Soldering Guide.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Johnnie Cairns
メンバー登録日: 02/10/16
522 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-6, Sullivan Spring 2016 USF Tampa, Team 2-6, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G6
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 35
今までの合計 1,582
