はじめに
If your device is not turning on, it is possible that the wiring that connects the batteries to the motherboard is ruptured. This guide will give directions on replacing these wires.
必要な工具と部品
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Visually inspect the wires connecting the motherboard to the batteries, looking for damage.
ある他の人がこのガイドを完成しました。
