メインコンテンツにスキップ
UE BOOM 2 Battery Replacement
必要な工具と部品
  1. UE BOOM 2 Battery Replacement, Battery: 手順 1、 2の画像 1 UE BOOM 2 Battery Replacement, Battery: 手順 1、 2の画像 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Battery Replacement: 手順 2、 2の画像 1 UE BOOM 2 Battery Replacement: 手順 2、 2の画像 2
    • After the D-ring has been removed, remove the rubber port cover.
  3. UE BOOM 2 Battery Replacement: 手順 3、 3の画像 1 UE BOOM 2 Battery Replacement: 手順 3、 3の画像 2 UE BOOM 2 Battery Replacement: 手順 3、 3の画像 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    • It is not necessary to entirely remove the rubber stripping. Simply popping the cap is adequate.
    Note - the end cap is an assembly of rubber pad glued to a plastic cap. Make sure you pry up from under the edge of the plastic cap, not remove the rubber alone.
    You don’t need to continue down the side as mentioned below.
    rogkellidean - 返信
    This step is a little bit hard. It requires little bit more force. Make sure not to damage the silicon part, push the tool more in where you can feel the hard plastic part.
    Márk Baráz - 返信
    Quite difficult non to break the retaining clips: be slow and careful. Here is a close view of the clips… so that you know what you have to manage…
    https://youtube.com/shorts/jeU21ZM7roA?f...
    Gianluca Meardi - 返信
    I can't get it off. The metal spudger just bends.
    uumas - 返信
  4. UE BOOM 2 Battery Replacement: 手順 4、 1の画像 1
    • Continue removing the rubber stripping down the side if you intend to replace it.
  5. UE BOOM 2 Battery Replacement: 手順 5、 3の画像 1 UE BOOM 2 Battery Replacement: 手順 5、 3の画像 2 UE BOOM 2 Battery Replacement: 手順 5、 3の画像 3
    • Use a Phillips #2 screwdriver to unscrew the four 15mm screws on the bottom of the speaker. DO NOT OPEN SIDE WITH RED CAP (AS SHOWN IN SOME IMAGES), BATTERY IS ON OPPOSITE SIDE
    • Use a metal spudger to pry up the plastic cap.
    Guide is missing a step as there are no screws under the rubber strip.
    Jack Arnold - 返信
    In the picture, the instructor is taking off the top of the speaker. DO NOT DO THIS. You must take off the bottom.
    Tanner Bilcowski - 返信
    If you make the mistake of opening the top and pulling out the board that holds the power button, what may help you align the board back is undoing the fabric cover clips right on top of the volume up button and gently sliding that board back into place. The connectors aren't as forgiving (yup, it just slides through holes in PCB) as the bottom ones that have tapered female ends so go slow and gently as you can.
    Matthew Ballard - 返信
    Wish I read these comments before trying this step.
    GGAmber - 返信
    Future readers: Do not.... I repeat, DO NOT follow ANY of this article. I now have a UE Boom 2 that is a complete sh@#show! Rubber I can't fix, and scratches all over like you wouldn't believe. Listen to the previous comments instead. I now have to glue the rubber back on to mine.
    tre-rocks - 返信
    Ok no screws - feeling really stupid for starting this and ordering the stuff from Ifixit
    Mary Johnson - 返信
    Same as above there are no screws visible and I am feeling really stupid from ordering the stuff from IFIxIt. Any solutions?
    Mary Johnson - 返信
    You only have to open the bottom cap. No need to remove the lateral.
    Quite difficult non to break the retaining clips of the bottom cap: be slow and careful. Here is a close view of the clips… so that you know what you have to manage… https://youtube.com/shorts/jeU21ZM7roA?f...
    In any case, after having replaced the battery, the cap does not close anymore like new: I’ve now about a 0.7-1mm gap. Not a problem for water (shower, not submersion) anyhow, as the impermeability is given by the second cap inside.
    But… my dear UE Boom designers… it’s really sad that such a nice sounding device is so badly designed to replace a simple battery (something that is mandatory after some 2-4 years of usage… especially if very limited usage): quite disappointed!
    Gianluca Meardi , c'est lui qui à raison, donc , croyez le !......
    Philippe Garnier - 返信
  6. UE BOOM 2 Battery Replacement: 手順 6、 2の画像 1 UE BOOM 2 Battery Replacement: 手順 6、 2の画像 2
    • Carefully unseat the battery cable from the retaining posts.
    • Squeeze the small black clip on the battery connector, then lift the connector to unplug it.
    • Slowly pull out the battery, and handle with care.
    I can not disconnect the battery from the motherboard!!
    Cathleen Maugeri - 返信
    I had the same problem. However, I eventually found that if you push the little clip in towards the main part of the connector, it comes free easily. Hope that helps!
    kennydoitnow -
    I have the same problem as Cathleen. Is there a small clip that needs to be undone on the battery cable?
    benjaminlaird - 返信
    Battery What type of battery is better and how many amperes?
    Wira Ananta - 返信
    What type of 18650 battery is in amperage and how many pieces are needed
    Wira Ananta - 返信
    Any tips on how to replace the rubber cover? Is a type of glue needed?
    Ramon Macias - 返信
    I had the same problem as Cathleen, too. However, I eventually found that if you push the little clip in towards the main part of the connector, it comes free easily. Hope that helps!
    kennydoitnow - 返信
    Hello do you know where I could get the part with the PCB that holds the female jack and the power inlet
    Laurent BUGEAT - 返信
    Armed with no spludgers but lots of brute force and ignorance I managed to bust the clips. I've explained to daughter it's a one time repair and I'm going to glue it shut when I get the new battery!
    Gwyn Carwardine - 返信
    Can someone please tell what type of battery to use to replace the old one.
    Thank you
    MsYazz - 返信
終わりに
For optimal performance, calibrate your newly installed battery after completing this guide.
50 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Brandon Yowakim
メンバー登録日: 01/18/18
1,230 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S1-G3, Zimmerman Spring 2020 Cal Poly, Team S1-G3, Zimmerman Spring 2020人のメンバー
CPSU-ZIMMERMAN-S20S1G3
5 メンバー
11のガイドは作成済み
27 Guide Comments
what kind of battery ?and do you have a link to buy one
wrig5235 - 返信
I was looking for a battery replacement all over the place. Came up with this site that carries parts for the Boom 2:
https://www.joesge.com/products/ue-ultim...
Frederic - 返信
Why is this set to difficult though? It doesn’t look THAT hard… And will this affect waterproofing of the feature?
Frederic - 返信
Because you do not simply stick the plunger in and pop those tabs. They are a force of evil and I even bent my metal tools to open mine.
Joseph Murphy -
It isn't that hard if you've done a couple of repairs, although you gotta work slow and really make sure you got yourself like 3-4 spudger like items (butter knife) and look at reference images where the tabs are. Btw. You don't need to remove more than the bottom plastics and the plate with 4 screws to change the battery. Managed to change my battery while not damaging a single plastic tab
Lucas Schießl -
People replacing the battery be warned, you can buy a battery from China for 17 shipped on eBay, however what this guide does not tell you is one you open it, and re close it, there will forever be a gap on the top and bottom between the mesh and the rubberish spine. I have not since then tested the water proof feature because of this gap. You are warned and he should have warned us as well.
Joseph Murphy - 返信
I managed it without a gap using e/t-6000 tech glue and some clamps and tape, you could also try:
- harvesting and cutting the adhesive strips out of an old iPhone or Samsung screen replacement kit
-that good old orange double sided tape.
BP 159 -
Missing a step, after removing the rubber you are met with smooth caps on the top & bottom of the speaker, no screws holes
Jack Arnold - 返信
Be careful to unscrew only the bottom part and leave the top part in place (the photo is misleading, he removes the top part). the bottom is where the battery is.
lginoux - 返信
Is this just a standard 18650 battery? Looks like it from the picture.
Tim Ligtermoet - 返信
Will it effect the waterproofing?
Jake Militano - 返信
If not done correctly, 100%
Lucas Schießl -
What have my ue boom ,sound comes on and goes off when is’s fully charged
Wesley Inia - 返信
What's the course of a ue boom when turning it on, sound comes on and goes off again the sound don't finish but cut off not complete sound comes on just half sound only,but it's fully charged
Wesley Inia - 返信
What's the course of a ue boom when turning it on and goes off again the sound comes on just half sound not really the complete sound
Wesley Inia - 返信
Then we buy a new battery or we just replace the same one. Please clarify me here?
GILBERTH IMBUN - 返信
What do you mean exactly? You need to buy a new battery and replace the one in the speaker with the new one.
Elias Bürgisser -
Does Somebody also has this Problem?
I changed the battery, everything worked fine. But when I cranked the volume at the maximum, the speakers suddenly shut down and they only work again after inserting the original battery. I bought two batteries from different sources and both had the same problem. Is it just bad luck or does anybody else has this problem?
Elias Bürgisser - 返信
You need to get the same type of battery as the original. The original is probably a high discharge cell so that it can supply the strength to power higher volumes. There should be markings on the original that give a clue to what the exact cell is in there.
Nemat Heydary -
Doing this will cause cosmetic damage to the device around the base. This does not damage the waterproofing.
Waterproofing is provided by:
A) the rubber cap held on by the D ring protects the USB/AUX ports.
b) The purple O ring under the black plastic cap held in by the 4 Phillips screws.
So, if you put all that back correctly, the waterproofing will be fine.
I found that To more easily remove the top, Re-install the D-ring during step 3, then unscrew it 1.5 turns, and grip it with a pair of vice grips.
The vice grips in combination with the Spudger will ease removing the top cover. BE GENTLE, you don’t want to tear the rubber!
If you remove the blue rubber, and it’s smooth plastic underneath instead of 4 screws, you %@#%ed up, and separated the rubber over-molding from the top plastic.
Adrian Neill - 返信
Thanks Adrian!
Most helpful post here!
Thangfish -
How this guide became “Featured” is beyond me. Some of the pictures show him opening up the wrong end of the speaker, but most importantly the technique shown here WILL break stuff. The way the top/lid is made makes it impossible to open like this without breaking the structure.
It will however mostly go back together, so it is possible to do it like this, just know that it wont be entirely like before. From what I gather the rubber seals are positioned so that the speaker should still be waterproof after changing the battery.
I took a lot of pics of mine after I opened it, shown here: https://www.reddit.com/gallery/iqq59a
erlendds - 返信
The spudger isn’t the right tool to try and open the case. It bends way too easily. I used a large flat head screwdriver, which had the right leverage to try and open the case.
C W - 返信
used two small flat head screwdrivers to work around popping cap; worked fine, be sure to insert the blades between the cap teeth. I received a small circuit board with battery; what is that for?
William Wade - 返信
Excellent guide. Beware though, it’s more about finding the right spots to put the spludge in since you need to pop the tabs. I think i broke one but there’s like 7 left so it’s pretty much as good as before. Except now the battery isn’t drained everytime I want to listen to it.
andersson.d - 返信
Can I send my UE boom in somewhere to fix it?
Leah Mulder - 返信
I replaced my battery with another recharge battery and for some reason it still won't hold a charge and ever time I try to place music one it is connected it shuts off
Manonthemoon812 - 返信
コメントを追加
統計データ:
過去 24時間: 26
過去 7 日: 206
過去 30 日: 1,034
今までの合計 131,143
