メインコンテンツにスキップ
Toshiba Satellite L55-A Battery Replacement
必要な工具と部品
  1. Toshiba Satellite L55-A Battery Replacement, Remove the RAM cover: 手順 1、 1の画像 1
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A Battery Replacement: 手順 2、 2の画像 1 Toshiba Satellite L55-A Battery Replacement: 手順 2、 2の画像 2
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: 手順 3、 3の画像 1 Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: 手順 3、 3の画像 2 Toshiba Satellite L55-A Battery Replacement, Disconnect the ethernet connector cable: 手順 3、 3の画像 3
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A Battery Replacement, Remove the back cover: 手順 4、 1の画像 1
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A Battery Replacement: 手順 5、 3の画像 1 Toshiba Satellite L55-A Battery Replacement: 手順 5、 3の画像 2 Toshiba Satellite L55-A Battery Replacement: 手順 5、 3の画像 3
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A Battery Replacement: 手順 6、 2の画像 1 Toshiba Satellite L55-A Battery Replacement: 手順 6、 2の画像 2
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A Battery Replacement: 手順 7、 3の画像 1 Toshiba Satellite L55-A Battery Replacement: 手順 7、 3の画像 2 Toshiba Satellite L55-A Battery Replacement: 手順 7、 3の画像 3
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
  8. Toshiba Satellite L55-A Battery Replacement, Unscrew the battery: 手順 8、 1の画像 1
    • Remove the two 6.8 mm long Phillips screws securing the battery.
  9. Toshiba Satellite L55-A Battery Replacement: 手順 9、 2の画像 1 Toshiba Satellite L55-A Battery Replacement: 手順 9、 2の画像 2
    • Lift the battery out of its recess and move it slightly away from the motherboard in order to reveal the battery cable.
  10. Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: 手順 10、 2の画像 1 Toshiba Satellite L55-A Battery Replacement, Disconnect the battery: 手順 10、 2の画像 2
    • Grasp the battery cable near its motherboard socket and pull the connector horizontally out of the socket.
  11. Toshiba Satellite L55-A Battery Replacement, Remove the battery: 手順 11、 1の画像 1
    • Remove the battery.
終わりに
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
作成者
1人の作成者と共同作成されました。
Arthur Shi
メンバー登録日: 01/03/18
253,576 ポイント
526のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,214のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 30
今までの合計 1,614
