メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Claw Circuit Board Replacement
必要な工具と部品
    1. The Claw Circuit Board Replacement, Bottom Cover: 手順 1、 1の画像 1
      • Place The Claw in upright position with controls facing you.
      FixBotに聞いてみる
      コメントを追加
    2. The Claw Circuit Board Replacement: 手順 2、 1の画像 1
      • Gently flip The Claw machine upside down with the controls facing you.
      FixBotに聞いてみる
      コメントを追加
    3. The Claw Circuit Board Replacement: 手順 3、 1の画像 1
      • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
      • You will need a screwdriver with a long thin neck to fit in the screw holes.
      FixBotに聞いてみる
      コメントを追加
    4. The Claw Circuit Board Replacement: 手順 4、 2の画像 1 The Claw Circuit Board Replacement: 手順 4、 2の画像 2
      • Slide the bottom cover off to the side.
      • Do not completely remove bottom cover as it is still connected to wires.
      FixBotに聞いてみる
      コメントを追加
    5. The Claw Circuit Board Replacement: 手順 5、 1の画像 1
      • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
      • You will need to cut the two green wires attached to the music player.
      • Then you will need to cut the white wire that leads to the battery compartment.
      • Finally you will need to cut the black wire leading to the battery compartment as well.
      • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: はんだ付けとはんだ除去の作業ガイド.
      FixBotに聞いてみる
      コメントを追加
    1. The Claw Circuit Board Replacement, Circuit Board: 手順 6、 1の画像 1
      • Once you have removed the bottom cover you should have clear access to the circuit board.
      • Locate the circuit board in the bottom of The Claw machine.
      FixBotに聞いてみる
      コメントを追加
    2. The Claw Circuit Board Replacement: 手順 7、 1の画像 1
      • Locate the screws that hold the circuit board in place.
      FixBotに聞いてみる
      コメントを追加
    3. The Claw Circuit Board Replacement: 手順 8、 1の画像 1
      • Be sure to turn off the device and remove the batteries before reaching into the device with your hands or any metal tools.
      • Using a Phillips #1 screwdriver, remove the four 6mm that hold the circuit board in place.
      • You will also need to cut all of the wires leading to the circuit board to completely remove it.
      FixBotに聞いてみる
      コメントを追加
    4. The Claw Circuit Board Replacement: 手順 9、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alain Pierre
メンバー登録日: 03/22/16
1,188 ポイント
9のガイドは作成済み
チーム
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S4G8
3 メンバー
18のガイドは作成済み
9件のガイドコメント
I accidentally cut the wires where the motors are and now can not figure out which go where, is there a diagram or drawling of where each wire goes?
Dyn4mic Universe - 返信 共有
Did you ever find a diagram for this? I would like to have one also….
Nathan Riffel - 返信 共有
Does anybody know where to get the replacement switches for these?
Bill B. - 返信 共有
Same. I am in need of the replacements as well.
Allison Rousseau - 返信 共有
Me too. L/R switch doesn't work need to replace it.
Johnny Annon - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 84
今までの合計 7,844
