メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SuperSonic Matrix Mid SC-999 LCD Replacement
必要な工具と部品
  1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: 手順 1、 1の画像 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
    FixBotに聞いてみる
    コメントを追加
  2. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 2、 1の画像 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
    FixBotに聞いてみる
    コメントを追加
  3. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 3、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 3、 2の画像 2
    • Lift the back cover from the body of the device to expose the internal components.
    FixBotに聞いてみる
    コメントを追加
  4. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 手順 4、 3の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 手順 4、 3の画像 2 SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: 手順 4、 3の画像 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
    FixBotに聞いてみる
    コメントを追加
  5. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 5、 3の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 5、 3の画像 2 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 5、 3の画像 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
    FixBotに聞いてみる
    コメントを追加
  6. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
    FixBotに聞いてみる
    コメントを追加
  7. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 7、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 7、 2の画像 2
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
    FixBotに聞いてみる
    コメントを追加
  8. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: 手順 8、 1の画像 1
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
    FixBotに聞いてみる
    コメントを追加
  9. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 9、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 9、 2の画像 2
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
    FixBotに聞いてみる
    コメントを追加
  10. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: 手順 10、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: 手順 10、 2の画像 2
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
    FixBotに聞いてみる
    コメントを追加
  11. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 11、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 11、 2の画像 2
    • Desolder the FM antenna from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  12. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: 手順 12、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: 手順 12、 2の画像 2
    • Remove the large ribbon cable from the socket that attaches it to the motherboard.
    • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
    FixBotに聞いてみる
    コメントを追加
  13. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 13、 2の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 13、 2の画像 2
    • Remove the small ribbon cable from the socket that attaches it to the motherboard.
    • Flip the dark grey latch to release the ribbon cable from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  14. SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 14、 3の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 14、 3の画像 2 SuperSonic Matrix Mid SC-999 LCD Replacement: 手順 14、 3の画像 3
    • Remove the four Phillips #00 screws attaching the motherboard to the device.
    FixBotに聞いてみる
    コメントを追加
  15. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 手順 15、 3の画像 1 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 手順 15、 3の画像 2 SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: 手順 15、 3の画像 3
    • Ensure that the motherboard and all other items are off before continuing.
    • Separate the screen and back housing by gently pulling on it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Harris Dagha
メンバー登録日: 03/26/15
866 ポイント
7のガイドは作成済み
チーム
Dr Shaverz boyz Dr Shaverz boyz人のメンバー
Community
3 メンバー
14のガイドは作成済み
1件のガイドコメント
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 1,351
