メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Speaker Unit Replacement
必要な工具と部品
  1. Speaker Unit Replacement, Exterior Housing: 手順 1、 3の画像 1 Speaker Unit Replacement, Exterior Housing: 手順 1、 3の画像 2 Speaker Unit Replacement, Exterior Housing: 手順 1、 3の画像 3
    この手順で使用する道具:
    iOpener
    $24.95
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
    FixBotに聞いてみる
    コメントを追加
  2. Speaker Unit Replacement, Speaker Unit: 手順 2、 1の画像 1
    • Remove these eight 9 mm screws using a Phillips #2 driver.
    FixBotに聞いてみる
    コメントを追加
  3. Speaker Unit Replacement: 手順 3、 1の画像 1
    • Carefully lift the cover off. It may be a little sticky from glue.
    FixBotに聞いてみる
    コメントを追加
  4. Speaker Unit Replacement: 手順 4、 1の画像 1
    • Remove the four 6mm screws that hold the broken speaker in place. This step requires a Phillips #1 driver. If you are replacing both speakers, remove all 8 screws.
    FixBotに聞いてみる
    コメントを追加
  5. Speaker Unit Replacement: 手順 5、 1の画像 1
    • Caution: the speaker is fitted quite snug. it may take a bit of effort to remove. However, be careful not to pull too hard as you may accidentally pull on the wires once the speaker unit is free.
    • Hold the speaker by its cylindrical frame and cautiously lift it away from the rest of the device.
    FixBotに聞いてみる
    コメントを追加
  6. Speaker Unit Replacement: 手順 6、 1の画像 1
    • De-solder the existing soldered connections and remove the speaker from the rest of the device.
    • Insert and solder in a working speaker of the same model. Make sure the points where the wire ends connected are consistent with the old speakers.
    • Note: If you notice that a wire is disconnected, this may be the cause of your problems. Re-solder the connection to fix it.
    • You can refer to iFixit's guide or this informative video for more information on soldering.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jerrell
メンバー登録日: 04/23/14
730 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G50
4 メンバー
10のガイドは作成済み
1件のガイドコメント
Good afternoom, my name is vladimir and i ‘m interested both speakers, where i could fi nd them to replace in my ihome? Could you help me?
Vladinir reyes - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 34
今までの合計 1,424
