メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony SRS-XB43 LED Module Replacement
必要な工具と部品
    1. Sony SRS-XB43 LED Module Replacement, Faceplate: 手順 1、 2の画像 1 Sony SRS-XB43 LED Module Replacement, Faceplate: 手順 1、 2の画像 2
      • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
      • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
      • Fully open the hinged mesh cover and pry it off the unit.
      FixBotに聞いてみる
      コメントを追加
    2. Sony SRS-XB43 LED Module Replacement: 手順 2、 1の画像 1
      • Turn the speaker so the back is facing you.
      • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
      • Remove the single screw using a T8 Torx.
      FixBotに聞いてみる
      コメントを追加
    3. Sony SRS-XB43 LED Module Replacement: 手順 3、 1の画像 1
      • Remove all ten screws using a Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    4. Sony SRS-XB43 LED Module Replacement: 手順 4、 2の画像 1 Sony SRS-XB43 LED Module Replacement: 手順 4、 2の画像 2
      • Slowly lift the speaker face off of the housing unit.
      • Unplug the six wires connecting the faceplate to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    1. Sony SRS-XB43 LED Module Replacement, Battery: 手順 5、 2の画像 1 Sony SRS-XB43 LED Module Replacement, Battery: 手順 5、 2の画像 2
      • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
      • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
      • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
      FixBotに聞いてみる
      コメントを追加
    2. Sony SRS-XB43 LED Module Replacement: 手順 6、 3の画像 1 Sony SRS-XB43 LED Module Replacement: 手順 6、 3の画像 2 Sony SRS-XB43 LED Module Replacement: 手順 6、 3の画像 3
      • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
      • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
      FixBotに聞いてみる
      コメントを追加
    3. Sony SRS-XB43 LED Module Replacement: 手順 7、 2の画像 1 Sony SRS-XB43 LED Module Replacement: 手順 7、 2の画像 2
      • Orient the plastic chassis so that the port housing PCB is facing upward.
      • Remove the plastic black film covering the battery, leaving the blue battery exposed.
      FixBotに聞いてみる
      コメントを追加
    4. Sony SRS-XB43 LED Module Replacement: 手順 8、 2の画像 1 Sony SRS-XB43 LED Module Replacement: 手順 8、 2の画像 2
      • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
      • Using your fingers, pull upwards until the battery is removed from its enclosure.
      • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
      FixBotに聞いてみる
      コメントを追加
    1. Sony SRS-XB43 LED Module Replacement, LED Module: 手順 9、 1の画像 1
      • Orient the motherboard chassis so that the battery compartment is facing upwards.
      • Identify the two LED control PCBs located on the left and right edges of the plastic chassis.
      FixBotに聞いてみる
      コメントを追加
    2. Sony SRS-XB43 LED Module Replacement: 手順 10、 3の画像 1 Sony SRS-XB43 LED Module Replacement: 手順 10、 3の画像 2 Sony SRS-XB43 LED Module Replacement: 手順 10、 3の画像 3
      • Identify the black latch on each of the plugs that are connected to the PBCs.
      • Swing the black latch open by gently prying the front/extruding lip of the plug with a spudger or other flat tool.
      • To give a sense of direction, the latch should swing away from you or towards the LED (metallic square).
      • Grab each ribbon cable and apply a horizontal pulling force (with respect to the LED control PCBs) to disconnect them from the connectors.
      FixBotに聞いてみる
      コメントを追加
    3. Sony SRS-XB43 LED Module Replacement: 手順 11、 3の画像 1 Sony SRS-XB43 LED Module Replacement: 手順 11、 3の画像 2 Sony SRS-XB43 LED Module Replacement: 手順 11、 3の画像 3
      この手順で使用する道具:
      Plastic Cards
      $2.99
      • Insert the spudger below the LED control PCBs and pry to remove it from the plastic chassis.
      • The PCBs are held onto the chassis with a considerably strong double-sided tape. If the spudger is too thick and can not fit under the PCBs, use a thin plastic pick or plastic card.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Isaac Oliveira
メンバー登録日: 10/26/22
282 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022人のメンバー
UMASSD-BOTVIN-F22S3G5
4 メンバー
10のガイドは作成済み
1件のガイドコメント
i need email to contact You please
Danny Bryan Vega - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 40
今までの合計 972
