はじめに
In the situation that your Sony BDP-BX510 Wi-Fi module is not working despite trying the solutions on the troubleshooting page, you may need to replace it. This guide will provide you with the steps required to safely remove your Wi-Fi module for replacement.
必要な工具と部品
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
Find the large ribbon cable that connects the port board to the motherboard.
Carefully pull directly upwards to disconnect the cable.
