メインコンテンツにスキップ
Solio CLASSIC2 USB Port Replacement
必要な工具と部品
  1. Solio CLASSIC2 USB Port Replacement, Disconnecting the Battery: 手順 1、 1の画像 1
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 USB Port Replacement: 手順 2、 1の画像 1
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 USB Port Replacement: 手順 3、 3の画像 1 Solio CLASSIC2 USB Port Replacement: 手順 3、 3の画像 2 Solio CLASSIC2 USB Port Replacement: 手順 3、 3の画像 3
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 USB Port Replacement: 手順 4、 2の画像 1 Solio CLASSIC2 USB Port Replacement: 手順 4、 2の画像 2
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 USB Port Replacement: 手順 5、 2の画像 1 Solio CLASSIC2 USB Port Replacement: 手順 5、 2の画像 2
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 USB Port Replacement: 手順 6、 2の画像 1 Solio CLASSIC2 USB Port Replacement: 手順 6、 2の画像 2
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 USB Port Replacement, Circuit Board: 手順 7、 1の画像 1
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 USB Port Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
  9. Solio CLASSIC2 USB Port Replacement, USB Port: 手順 9、 1の画像 1
    • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
    • Remove solder from both spots on outside of the USB port.
    • Remove solder from base of the USB port.
終わりに
作成者
3人の作成者と共同で作成されました。
Anthony Ramos
メンバー登録日: 10/20/13
102 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S4G28
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 21
今までの合計 1,135
