はじめに
This repair guide will walk you through the primary steps of replacing the battery in the Skytex Skypad SP728.
必要な工具と部品
Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
Follow the link below for additional soldering information はんだ付けとはんだ除去の作業ガイド
To reassemble your device with a new battery, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
