メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Refrigerator Control Board Replacement
必要な工具と部品
  1. Samsung Refrigerator Control Board Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    FixBotに聞いてみる
    コメントを追加
  2. Samsung Refrigerator Control Board Replacement, Remove the board access panel: 手順 2、 1の画像 1
    • Remove the screws securing the board access panel to the back of the refrigerator.
    FixBotに聞いてみる
    コメントを追加
  3. Samsung Refrigerator Control Board Replacement: 手順 3、 2の画像 1 Samsung Refrigerator Control Board Replacement: 手順 3、 2の画像 2
    • Remove the board access panel.
    FixBotに聞いてみる
    コメントを追加
  4. Samsung Refrigerator Control Board Replacement, Reassembly information: 手順 4、 2の画像 1 Samsung Refrigerator Control Board Replacement, Reassembly information: 手順 4、 2の画像 2
    • Note the locations and number of the connectors on the control board, and photograph them or draw a diagram. This example control board has nine wire connectors:
    • Three connectors along the top edge
    • One connector along the right edge
    • One connector along the bottom edge
    • Four connectors along the left edge
    • During reassembly, use your diagram or the photo you took (like the second image here) to make sure you've reconnected all of the connectors.
    FixBotに聞いてみる
    コメントを追加
  5. Samsung Refrigerator Control Board Replacement, Remove the control board: 手順 5、 2の画像 1 Samsung Refrigerator Control Board Replacement, Remove the control board: 手順 5、 2の画像 2
    • Pull and disconnect each of the connectors from the control board.
    • Some connectors may have a locking tab. Squeeze the wide sides of the connector to unlock it, then pull to disconnect it.
    • Move the wires away from the control board so it can swing out of its recess.
    FixBotに聞いてみる
    コメントを追加
  6. Samsung Refrigerator Control Board Replacement: 手順 6、 3の画像 1 Samsung Refrigerator Control Board Replacement: 手順 6、 3の画像 2 Samsung Refrigerator Control Board Replacement: 手順 6、 3の画像 3
    • Use your fingers to push up the plastic lip securing the top edge of the control board to the refrigerator.
    • Swing the control board out and remove it.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn’t go as planned? Ask our Answers Community for help.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Bill Gilbert
メンバー登録日: 06/30/22
40,140 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
31,437のガイドは作成済み
5件のガイドコメント
My tempura in my new refrigerator isn’t working right , I bought earlier this year
Carolyn whittaker - 返信 共有
Is this Samsung
Do you have a phone number
Samsung fridge- after changing a water filter, bottom drawer freezer stopped making ice.
It is set for 0 but no ice. I bought this fridge last year.
Sewell Nikki - 返信 共有
My refrigerator light is on but the comppresor is not working and anytime I on it is not piping sounds again
Asiafa - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 85
過去 30 日: 400
今までの合計 8,941
