はじめに
Replacing the Wi-Fi card may be necessary if your Samsung Impression experiences slow or unstable internet connections. This guide will show you how to remove and install a new Wi-Fi card to restore proper functionality.
Before beginning, power off the device and disconnect the battery to prevent electrical damage. This repair involves handling small internal components. Use caution when working inside the device, as cables and connectors are fragile and can be easily damaged.
必要な工具と部品
Orient the phone with the screen facing downward.
Slide the panel away from the camera using your thumb. This will expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
Gently remove the black wire to free the circuit board.
Remove the wire by gently prying up the gold terminator attached to the green circuit board.
Use a Phillips screwdriver to remove the six 3.5 mm screws by rotating.
The antenna assembly will snap off.
To replace the antenna and reassemble your device, follow the steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
ある他の人がこのガイドを完成しました。
