メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Samsung Galaxy Note8 Back Cover Replacement
必要な工具と部品
  1. Samsung Galaxy Note8 Back Cover Replacement, Back Cover: 手順 1、 1の画像 1
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
  2. Samsung Galaxy Note8 Back Cover Replacement: 手順 2、 3の画像 1 Samsung Galaxy Note8 Back Cover Replacement: 手順 2、 3の画像 2 Samsung Galaxy Note8 Back Cover Replacement: 手順 2、 3の画像 3
    • Use a suction handle to lift the back cover and an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
  3. Samsung Galaxy Note8 Back Cover Replacement: 手順 3、 3の画像 1 Samsung Galaxy Note8 Back Cover Replacement: 手順 3、 3の画像 2 Samsung Galaxy Note8 Back Cover Replacement: 手順 3、 3の画像 3
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
  4. Samsung Galaxy Note8 Back Cover Replacement: 手順 4、 3の画像 1 Samsung Galaxy Note8 Back Cover Replacement: 手順 4、 3の画像 2 Samsung Galaxy Note8 Back Cover Replacement: 手順 4、 3の画像 3
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy Note8 Back Cover Replacement: 手順 5、 3の画像 1 Samsung Galaxy Note8 Back Cover Replacement: 手順 5、 3の画像 2 Samsung Galaxy Note8 Back Cover Replacement: 手順 5、 3の画像 3
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
  6. Samsung Galaxy Note8 Back Cover Replacement: 手順 6、 1の画像 1
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
  7. Samsung Galaxy Note8 Back Cover Replacement: 手順 7、 1の画像 1
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
終わりに
If possible, turn on your phone and test the new part before installing new adhesive and resealing the phone.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
42 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,598 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
3 件のコメント
My adhivsive was a pain in the but! Never fixed a phone that hard glued :O
Vidar G - 返信
the separate adhesive was unneeded the replacement back cover came with adhesive
Anthony Asp - 返信
So close!!!!’ I sliced the fingerprint sensor cable off, that area of the back glass was so smashed. Hopefully I can get a replacement to me by Saturday
Douglas Pocknett Jr - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 30
過去 30 日: 125
今までの合計 29,880
