メインコンテンツにスキップ
Samsung Galaxy Note5 Display Assembly Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Samsung Galaxy Note5 Display Assembly  Replacement, Display Assembly: 手順 1、 1の画像 1
    • Prepare an iOpener and apply it to the left edge of the display for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • The glue securing the display can be significantly stronger than the glue that secures the back cover. If necessary, switch to a hair dryer or heat gun in order to apply enough heat to weaken the adhesive.
  2. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 2、 2の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 2、 2の画像 2
    • Insert an opening pick between the plastic frame and the display assembly on the same edge you just heated.
    • The pick should reside above the pink shielding layer, which covers the OLED panel.
    • If you can see the pick through the front glass, you've inserted it between the OLED panel and the front glass. Remove the pick and try again.
  3. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 3、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 3、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 3、 3の画像 3
    • Slide the opening pick down the battery-side of the phone, separating the adhesive.
    • Stop when you get to the bottom of the battery to avoid damaging delicate capacitive buttons at the bottom of the display.
    • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
    • Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  4. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 4、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 4、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 4、 3の画像 3
    • Heat an iOpener and apply it to the non-battery-edge of the phone.
    • Insert a pick no more than 0.25 inches (~6 mm) into the bottom edge of the phone.
    • Carefully slide the pick along the edge, starting at the headphone jack, until you reach just past the charging port.
  5. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 5、 2の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 5、 2の画像 2
    • Slide an opening pick from the battery edge battery edge of the phone along the edge of the phone to safely cut over the capacitive button.
    • Leave the pick in place as you proceed to the next button.
  6. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 6、 2の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 6、 2の画像 2
    • Insert an opening pick under the bottom edge of the display directly below the daughterboard ribbon cable to cut over the other capacitive button.
    • Leave the pick in place.
  7. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 7、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 7、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 7、 3の画像 3
    • Slide an opening pick down the non-battery-edge of the phone, separating the adhesive.
  8. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 8、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 8、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 8、 3の画像 3
    • The non-battery-edge contains a wider swath of adhesive than the other sides. Insert the opening pick as deep as you can to cut through all of it.
    • If cutting is difficult, apply more heat as needed.
    • Leave the pick in place to prevent the adhesive from resealing, and grab another pick as you proceed to the next step.
  9. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 9、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 9、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 9、 3の画像 3
    • Cut along the top edge of the phone, making sure not to insert the pick more than 0.25 inches (~6 mm) to avoid damaging the front-facing sensors.
  10. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 10、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 10、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 10、 3の画像 3
    • Use the opening picks to cut any remaining adhesive holding the display to the frame.
    • Swing the frame away from the display assembly, threading the touchscreen connector through the frame.
  11. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 11、 3の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 11、 3の画像 2 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 11、 3の画像 3
    • Lift the frame away from the display assembly, threading the display connector through the frame.
    • Remove the frame.
  12. Samsung Galaxy Note5 Display Assembly  Replacement: 手順 12、 2の画像 1 Samsung Galaxy Note5 Display Assembly  Replacement: 手順 12、 2の画像 2
    • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments or other debris.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
    • This helps remove any remaining adhesive residue and preps the surface for the new display.
    • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged.
終わりに
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
To reassemble your device, follow the above steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
作成者
2人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
254,609 ポイント
529のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,430のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 52
