メインコンテンツにスキップ
Samsung Galaxy Book Pro 15" Rear Case Replacement
必要な工具と部品
  1. Samsung Galaxy Book Pro 15" Rear Case Replacement, Remove the rubber feet: 手順 1、 3の画像 1 Samsung Galaxy Book Pro 15" Rear Case Replacement, Remove the rubber feet: 手順 1、 3の画像 2 Samsung Galaxy Book Pro 15" Rear Case Replacement, Remove the rubber feet: 手順 1、 3の画像 3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Rear Case Replacement, Unfasten the rear case: 手順 2、 2の画像 1 Samsung Galaxy Book Pro 15" Rear Case Replacement, Unfasten the rear case: 手順 2、 2の画像 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  3. Samsung Galaxy Book Pro 15" Rear Case Replacement, Insert an opening pick: 手順 3、 3の画像 1 Samsung Galaxy Book Pro 15" Rear Case Replacement, Insert an opening pick: 手順 3、 3の画像 2 Samsung Galaxy Book Pro 15" Rear Case Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Rear Case Replacement, Release the clips: 手順 4、 3の画像 1 Samsung Galaxy Book Pro 15" Rear Case Replacement, Release the clips: 手順 4、 3の画像 2 Samsung Galaxy Book Pro 15" Rear Case Replacement, Release the clips: 手順 4、 3の画像 3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Rear Case Replacement, Remove the rear case: 手順 5、 3の画像 1 Samsung Galaxy Book Pro 15" Rear Case Replacement, Remove the rear case: 手順 5、 3の画像 2 Samsung Galaxy Book Pro 15" Rear Case Replacement, Remove the rear case: 手順 5、 3の画像 3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
終わりに
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
作成者
2人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
124,642 ポイント
582のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 27
今までの合計 503
