メインコンテンツにスキップ
Samsung Galaxy A03s Screen Replacement
必要な工具と部品
  1. Samsung Galaxy A03s Screen Replacement, Eject SIM card tray: 手順 1、 1の画像 1
    • Remove the sim card by inserting a sim card tool into the sim card tray hole.
  2. Samsung Galaxy A03s Screen Replacement, Remove back cover: 手順 2、 3の画像 1 Samsung Galaxy A03s Screen Replacement, Remove back cover: 手順 2、 3の画像 2 Samsung Galaxy A03s Screen Replacement, Remove back cover: 手順 2、 3の画像 3
    • This cover has a series of plastic clips that attach it to the frame. Use your opening tool to gently pry the plastic back cover off.
    • Be careful inserting your opening tool near the power button. This button contains a fingerprint sensor with a ribbon cable that’s attached to the back cover. Do not cut this cable while removing the back cover.
    I never thought that
    Brayden - 返信
    This isn't too informative, you don't even show where it was started when opening and an isesemo is too thick to fit in between the screen and clips. Also how much force is applied to open the clips? Which way should you work around the phone?
    Zach Benson - 返信
  3. Samsung Galaxy A03s Screen Replacement, Remove power button: 手順 3、 1の画像 1
    • 2 plastic notches on the back cover hold the power button in place. Disconnect the power button from the back cover.
  4. Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: 手順 4、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Unfasten screws on camera lens bracket and loud speaker: 手順 4、 2の画像 2
    • 18 screws secure the camera lens bracket and loud speaker. All screws are the same size. Use a Phillips screwdriver to remove the 18 screws securing the camera lens bracket and loud speaker.
  5. Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: 手順 5、 3の画像 1 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: 手順 5、 3の画像 2 Samsung Galaxy A03s Screen Replacement, Remove camera lens bracket and loud speaker: 手順 5、 3の画像 3
    • Use your spudger to lift and remove the camera lens bracket and loud speaker.
  6. Samsung Galaxy A03s Screen Replacement, Disconnect battery: 手順 6、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Disconnect battery: 手順 6、 2の画像 2
    • Disconnect the battery cable by using a spudger
  7. Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: 手順 7、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Disconnect and remove power button: 手順 7、 2の画像 2
    • Use your spudger to disconnect the power button ribbon cable. Remove the power button.
  8. Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: 手順 8、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Disconnect and remove mainboard cable: 手順 8、 2の画像 2
    • Use your spudger to disconnect and remove the mainboard flex cable.
  9. Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: 手順 9、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Disconnect and remove antenna cable: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to disconnect and remove the black antenna cable on the mainboard and charging board
  10. Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: 手順 10、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Remove mainboard and charging board: 手順 10、 2の画像 2
    • Use your spudger to lift and remove mainboard and charging board
  11. Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: 手順 11、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Remove vibrate motor: 手順 11、 2の画像 2
    • Use heat and/or isopropyl alcohol to remove vibrate motor
    What is that yellow ribbon cable at the bottom to the side of the vibrate motor? I ordered a new screen and front frame, and while I was transferring things I accidentally punctured my battery. I had to get rid of the back frame, and it still had that part in it. I was too afraid of trying to get it out with the battery sizzling and sparking. The replacement front frame I bought doesn't have that in it, and I can't find it sold anywhere. Please someone help.
    Caden Helm - 返信
    Yeah so that's for a slightly different model, apparently they made the A037U and the other one, and I live in the US so i accidentally bought the international version..
    Caden Helm -
  12. Samsung Galaxy A03s Screen Replacement, Remove volume button flex: 手順 12、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Remove volume button flex: 手順 12、 2の画像 2
    • Use heat and/or isopropyl alcohol to remove volume button flex
    Be careful with this, I accidentally scraped off the button from the fpc... Had to order a new one for 10$
    Caden Helm - 返信
  13. Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: 手順 13、 2の画像 1 Samsung Galaxy A03s Screen Replacement, Remove earpiece speaker: 手順 13、 2の画像 2
    • Use spudger to remove earpiece speaker
  14. Samsung Galaxy A03s Screen Replacement, Remove battery: 手順 14、 1の画像 1
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Use heat and isopropyl alcohol to remove the battery.
    • Be careful to not puncture the battery while removing it.
    • There's a lot of adhesive under this battery and it can be tricky to remove. You can slide a thin plastic card underneath the battery to help break the adhesive.
    Why does the battery need to be removed
    Nihilistic Angel - 返信
    Never mind. Lmfao I’m slow bc both my screens have a battery
終わりに
31 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Matea
メンバー登録日: 05/05/23
1,117 ポイント
1ガイドが承認済み
6 件のコメント
Actually you guys are making it more complex and difficult than it needs to be or should ever have to be because I've repaired hundreds of Samsung Galaxy a03 s's and all Samsung Galaxy phones for that matter and the way you're going about in depth in detail and specific on a complete breakdown is too complex to be quite frankly honest with you you don't need to do all of this you're doing more work than what is really there honestly.
Harold Peterson - 返信
Are you going to offer the more simple solutions or no?
Missjentri -
Yeah, so do a better job
Timothy Bradford -
Can you post the simplest was to do this?
Chuck -
No carga solo logo de temperatura
Alan Rivera - 返信
@Harold Peterson
I need ur help replacing my a03 Core screen
Please the easiest way
0697440771 is my whatsapp no.🙏🏾
D$GĢ - 返信
コメントを追加
統計データ:
過去 24時間: 47
過去 7 日: 237
過去 30 日: 1,006
今までの合計 17,853
