メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
SEGA Genesis Flashback Controller Buttons Replacement
必要な工具と部品
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 手順 1、 3の画像 1 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 手順 1、 3の画像 2 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 手順 1、 3の画像 3
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    FixBotに聞いてみる
    コメントを追加
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: 手順 2、 2の画像 1 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: 手順 2、 2の画像 2
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    FixBotに聞いてみる
    コメントを追加
  3. SEGA Genesis Flashback Controller Buttons Replacement: 手順 3、 1の画像 1
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    FixBotに聞いてみる
    コメントを追加
  4. SEGA Genesis Flashback Controller Buttons Replacement: 手順 4、 1の画像 1
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    FixBotに聞いてみる
    コメントを追加
終わりに
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Viet Nguyen
メンバー登録日: 04/17/18
220 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S24G12
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 45
今までの合計 2,239
