はじめに
Use this guide to replace the face buttons on your Rotor Riot controller.
必要な工具と部品
Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
Remove the iPhone mount.
Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
Lift up the back cover of the controller.
Lift the back cover to a 45 degree angle and place it next to the controller.
Use a spudger to disconnect the phone connector cable from the mainboard.
Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
この手順で使用する道具:Tweezers$4.99
Use a pair of tweezers to remove the face buttons from the housing.
