メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Roborock S5 Laser Distance Sensor Motor Replacement
必要な工具と部品
    1. Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: 手順 1、 3の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: 手順 1、 3の画像 2 Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: 手順 1、 3の画像 3
      • Power down your Roborock S5.
      • Place it on a flat work surface with the power buttons facing toward you.
      • Use an opening tool to carefully pry under the section of the top panel with the buttons.
      • Gently pull upward to snap the panel off the top of the vacuum. It is secured in place by five snaps that you will need to release to remove the panel.
      • This can take some force, and the snaps can be quite loud. Be careful not to break the panel.
      FixBotに聞いてみる
      コメントを追加
    2. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 2、 3の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 2、 3の画像 2 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 2、 3の画像 3
      • Use a Phillips #2 screwdriver to remove the six 9 mm screws securing the other half of the top panel that covers the dust bin.
      • Remove the two hinge covers to free the other top panel.
      • Gently lift the other half of the top panel off of the robot vacuum.
      FixBotに聞いてみる
      コメントを追加
    3. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 3、 2の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 3、 2の画像 2
      • Use a spudger to pry off the rubber stoppers covering the three 12 mm screws that secure the Laser Distance Sensor housing cover.
      FixBotに聞いてみる
      コメントを追加
    4. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 4、 3の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 4、 3の画像 2 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 4、 3の画像 3
      • Use a Phillips #2 screwdriver to remove the three 12 mm screws holding the Laser Distance Sensor housing cover in place.
      • Use the same Phillips #2 screwdriver to remove the two 9 mm screws securing the Laser Distance Sensor housing cover.
      • Gently lift the cover off of the sensor.
      FixBotに聞いてみる
      コメントを追加
    5. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 5、 3の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 5、 3の画像 2 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 5、 3の画像 3
      • Use a Phillips #2 screwdriver to remove the four 9 mm screws holding the Laser Distance Sensor in place.
      • Gently lift it out of the robot vacuum.
      FixBotに聞いてみる
      コメントを追加
    6. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 6、 2の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 6、 2の画像 2
      • Turn the Laser Distance Sensor over so the backside is facing up.
      • Squeeze the tab against the connector, and pull the connector straight up from the socket to disconnect the power cable.
      FixBotに聞いてみる
      コメントを追加
    7. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 7、 3の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 7、 3の画像 2 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 7、 3の画像 3
      • Turn the Laser Distance Sensor housing back over.
      • Use a spudger to detach the plastic cord from the motor that connects it to the laser.
      • Use a Phillips #1 screwdriver to remove the two 4 mm screws attaching the motor to the housing.
      FixBotに聞いてみる
      コメントを追加
    8. Roborock S5 Laser Distance Sensor Motor Replacement: 手順 8、 2の画像 1 Roborock S5 Laser Distance Sensor Motor Replacement: 手順 8、 2の画像 2
      • Slide the orange gear out of the housing to remove it.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jacob Searcy
メンバー登録日: 09/13/23
992 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-1, Virtue Fall 2023 Western Carolina University, Team 1-1, Virtue Fall 2023人のメンバー
WCU-VIRTUE-F23S1G1
5 メンバー
17のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 60
過去 30 日: 197
今までの合計 5,865
