はじめに
If your Rienok S1 Mini charging port is damaged, follow these instructions to replace it.
The charging port allows the battery to be charged and the speaker to turn on, making it a necessary part for the speaker to function. If the port is damaged, it will need to be replaced by following the instructions here.
This guide does require soldering, and, If not done correctly, can damage the motherboard. For more information on soldering, see How To Solder and Desolder Connections.
Before beginning, ensure the power is off.
必要な工具と部品
Start with the buttons panel up and facing you.
Wedge in one iFixit opening pick, and apply outward pressure to pop out one side of the grille.
Using a second pick, slide from the first pick towards the opposite end until one whole side is popped out.
Wedge an iFixit opening pick into the space between the ring and the housing.
Insert a Jimmy into the gap created.
Apply an out-and-upward pressure with the Jimmy to disconnect the plastic clips surrounding the ring.
Work the Jimmy around the ring, disconnecting the clips along the way until they are all disconnected.
Insert a Jimmy into the seam between both halves.
Lightly twist the Jimmy until a small gap appears.
Work the Jimmy across the length creating and widening the gap as you go across.
With the gap across the whole length, grasp both halves and lightly pull apart.
DO NOT yank apart; the two halves are still connected by a few cords.
Grasp the rubber stop and lightly pull down to allow the motherboard to be removed.
