はじめに
The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
必要な工具と部品
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
Use the soldering iron to desolder and remove the red, blue, and three black wires.
To reassemble your device, follow steps one through seven in reverse order.
