メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Razer DeathAdder V3 Pro USB-C Port Replacement
必要な工具と部品
  1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: 手順 1、 3の画像 1 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: 手順 1、 3の画像 2 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: 手順 1、 3の画像 3
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. Razer DeathAdder V3 Pro USB-C Port Replacement: 手順 2、 2の画像 1 Razer DeathAdder V3 Pro USB-C Port Replacement: 手順 2、 2の画像 2
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    FixBotに聞いてみる
    コメントを追加
  3. Razer DeathAdder V3 Pro USB-C Port Replacement: 手順 3、 2の画像 1 Razer DeathAdder V3 Pro USB-C Port Replacement: 手順 3、 2の画像 2
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    FixBotに聞いてみる
    コメントを追加
  4. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: 手順 4、 1の画像 1
    • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
    • Unplug the battery from its connection on the right.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    • Remove the circuit board from the mouse.
    FixBotに聞いてみる
    コメントを追加
  5. Razer DeathAdder V3 Pro USB-C Port Replacement: 手順 5、 1の画像 1
    • Always solder in a well ventilated area.
    • Apply solder to the four anchor points on the back corners and side of the USB-C port.
    • Once the solder has melted, use tweezers to remove the USB-C port.
    • Use a solder sucker to clean the area.
    FixBotに聞いてみる
    コメントを追加
  6. Razer DeathAdder V3 Pro USB-C Port Replacement: 手順 6、 1の画像 1
    • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
    • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Nicholas
メンバー登録日: 09/24/25
453 ポイント
4のガイドは作成済み
チーム
Texas Tech, Team 2-5, Johansen Fall 2025 Texas Tech, Team 2-5, Johansen Fall 2025人のメンバー
TTU-JOHANSEN-F25S2G5
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 52
今までの合計 308
