メインコンテンツにスキップ
Razer Blade 15" (2018) Screen Replacement
必要な工具と部品
  1. Razer Blade 15" (2018) Screen Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 1 Razer Blade 15" (2018) Screen Replacement, Prepare your laptop for disassembly: 手順 1、 2の画像 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Screen Replacement, Unfasten the back cover: 手順 2、 1の画像 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Screen Replacement, Insert an opening pick: 手順 3、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Insert an opening pick: 手順 3、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Screen Replacement, Angle the opening pick: 手順 4、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Angle the opening pick: 手順 4、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Angle the opening pick: 手順 4、 3の画像 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Screen Replacement, Free the bottom right corner: 手順 5、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Free the bottom right corner: 手順 5、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Free the bottom right corner: 手順 5、 3の画像 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Screen Replacement, Free the front edge: 手順 6、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Free the front edge: 手順 6、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Free the front edge: 手順 6、 3の画像 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Screen Replacement, Remove the back cover: 手順 7、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Remove the back cover: 手順 7、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Remove the back cover: 手順 7、 3の画像 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Screen Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 1 Razer Blade 15" (2018) Screen Replacement, Soften the battery cable tape adhesive: 手順 8、 2の画像 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Screen Replacement, Peel up the battery cable tape: 手順 9、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Peel up the battery cable tape: 手順 9、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Peel up the battery cable tape: 手順 9、 3の画像 3
    この手順で使用する道具:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Screen Replacement, Disconnect the battery: 手順 10、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Disconnect the battery: 手順 10、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Disconnect the battery: 手順 10、 3の画像 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) Screen Replacement, Label the antenna cables: 手順 11、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Label the antenna cables: 手順 11、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Label the antenna cables: 手順 11、 3の画像 3
    • In the next steps, you'll disconnect and move the Wi-Fi cables to access other components.
    • The antenna cables look very similar. Label one of them with a piece of tape or marker. Do the same to its socket on the Wi-Fi card.
  12. Razer Blade 15" (2018) Screen Replacement, Disconnect the Wi-Fi card: 手順 12、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Disconnect the Wi-Fi card: 手順 12、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Disconnect the Wi-Fi card: 手順 12、 3の画像 3
    この手順で使用する道具:
    $3.99
    • Insert one arm of angled tweezers under the metal neck of each antenna cable and pry up to disconnect it.
  13. Razer Blade 15" (2018) Screen Replacement, Move the antenna cables: 手順 13、 2の画像 1 Razer Blade 15" (2018) Screen Replacement, Move the antenna cables: 手順 13、 2の画像 2
    • Use tweezers or your fingers to move the antenna cables to the left, away from the charging connector.
  14. Razer Blade 15" (2018) Screen Replacement, Disconnect the charging port: 手順 14、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Disconnect the charging port: 手順 14、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Disconnect the charging port: 手順 14、 3の画像 3
    • Use your spudger to push on alternating sides of the charging port connector to "walk" it out of its socket.
  15. Razer Blade 15" (2018) Screen Replacement, Remove the right hinge cover: 手順 15、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Remove the right hinge cover: 手順 15、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Remove the right hinge cover: 手順 15、 3の画像 3
    • Use a Phillips screwdriver to remove the three 6.7 mm screws securing the right hinge cover.
    • Remove the cover.
  16. Razer Blade 15" (2018) Screen Replacement, Remove the charging port: 手順 16、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Remove the charging port: 手順 16、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Remove the charging port: 手順 16、 3の画像 3
    • Tilt the charging port up and remove it.
  17. Razer Blade 15" (2018) Screen Replacement, Disconnect the screen: 手順 17、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Disconnect the screen: 手順 17、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Disconnect the screen: 手順 17、 3の画像 3
    • Grab the pull tab on the screen connector, to the left of the Wi-Fi card.
    • Pull up to disconnect the connector from its socket.
    • During reassembly, align the press connector over its socket and press down until it clicks into place. If it doesn't connect, re-align it and try again.
  18. Razer Blade 15" (2018) Screen Replacement, Free the screen cable: 手順 18、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Free the screen cable: 手順 18、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Free the screen cable: 手順 18、 3の画像 3
    • Guide the screen cable you just disconnected out from the tabs on the left fan.
    • Move the cable to the right, away from the laptop.
  19. Razer Blade 15" (2018) Screen Replacement, Free the antenna cables: 手順 19、 2の画像 1 Razer Blade 15" (2018) Screen Replacement, Free the antenna cables: 手順 19、 2の画像 2
    • Grab both antenna cables and guide them out from the tabs on the left fan.
  20. Razer Blade 15" (2018) Screen Replacement, Remove the left hinge cover: 手順 20、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Remove the left hinge cover: 手順 20、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Remove the left hinge cover: 手順 20、 3の画像 3
    • Use your Phillips screwdriver to remove the two 6.8 mm screws securing the left hinge cover.
    • Remove the hinge cover.
  21. Razer Blade 15" (2018) Screen Replacement, Disconnect the screen: 手順 21、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Disconnect the screen: 手順 21、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Disconnect the screen: 手順 21、 3の画像 3
    • Use the point of your spudger to push on alternating sides of the left screen connector, just under the right fan, to "walk" it out of its socket.
  22. Razer Blade 15" (2018) Screen Replacement, Free the screen cable: 手順 22、 2の画像 1 Razer Blade 15" (2018) Screen Replacement, Free the screen cable: 手順 22、 2の画像 2
    • Guide the left screen cable out from the tabs on the right fan.
  23. Razer Blade 15" (2018) Screen Replacement, Prop up the laptop: 手順 23、 1の画像 1
    • Open the screen and stand the laptop on its side, with the motherboard facing you.
  24. Razer Blade 15" (2018) Screen Replacement, Unfasten the screen hinges: 手順 24、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Unfasten the screen hinges: 手順 24、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Unfasten the screen hinges: 手順 24、 3の画像 3
    • If you prefer to lay the laptop flat while you work, lay it on a table with the screen hanging off for the next two steps.
    • Hold the laptop steady with one hand.
    • Use your Phillips screwdriver to remove the five 4.8 mm screws securing the screen hinges.
  25. Razer Blade 15" (2018) Screen Replacement, Remove the screen: 手順 25、 3の画像 1 Razer Blade 15" (2018) Screen Replacement, Remove the screen: 手順 25、 3の画像 2 Razer Blade 15" (2018) Screen Replacement, Remove the screen: 手順 25、 3の画像 3
    • Hold both halves of the laptop steady during this step, as they might fall unexpectedly.
    • Slide the screen hinges away from the frame to free them from their recesses.
    • Remove the screen.
終わりに
Clay Eickemeyer
メンバー登録日: 09/19/22
81,958 ポイント
455のガイドは作成済み
チーム
Guide Team Guide Team人のメンバー
Staff
9 メンバー
11,433のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 37
今までの合計 845
