メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PowerBook G4 Titanium Onyx Hard Drive Replacement
必要な工具と部品
      • Turn the G4 over.
      • Remove the eight T8 Torx screws from the lower case.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement: 手順 2、 1の画像 1
      • Using your thumbs, slide the lower case away from you.
      • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium Onyx Hard Drive Replacement: 手順 3、 1の画像 1
      • Your laptop should look approximately like this.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement, Airport Card: 手順 4、 1の画像 1
      • Skip this step if your computer does not have an Airport card.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
      • Disconnect the antenna cable from the left side of the Airport card.
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement, Hard Drive: 手順 5、 1の画像 1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium Onyx Hard Drive Replacement: 手順 6、 1の画像 1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      FixBotに聞いてみる
      コメントを追加
    3. PowerBook G4 Titanium Onyx Hard Drive Replacement: 手順 7、 1の画像 1
      • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      FixBotに聞いてみる
      コメントを追加
    4. PowerBook G4 Titanium Onyx Hard Drive Replacement: 手順 8、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement, Hard Drive: 手順 9、 1の画像 1
      • Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
      FixBotに聞いてみる
      コメントを追加
    2. PowerBook G4 Titanium Onyx Hard Drive Replacement: 手順 10、 1の画像 1
      • Grasp the orange ribbon cable and disconnect it from the hard drive. If the connector is tight, gently rock it from side to side.
      • Be sure to pull evenly on both sides as uneven force may damage the hard drive pins and render your data inaccessible.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
添付文書
作成者
5人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 56
今までの合計 13,731
