メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Polaroid PTAB7XC Screen Replacement
必要な工具と部品
    1. Polaroid PTAB7XC Screen Replacement, Screen: 手順 1、 2の画像 1 Polaroid PTAB7XC Screen Replacement, Screen: 手順 1、 2の画像 2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver and by turning the screws counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      FixBotに聞いてみる
      コメントを追加
    2. Polaroid PTAB7XC Screen Replacement: 手順 2、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 2、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 2、 3の画像 3
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      • The device is now free from the plastic casing.
      • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
      FixBotに聞いてみる
      コメントを追加
    3. Polaroid PTAB7XC Screen Replacement: 手順 3、 2の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 3、 2の画像 2
      この手順で使用する道具:
      Plastic Cards
      $2.99
      • Wedge a plastic card beneath the battery unit.
      • Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
      • Do not rupture the battery; it poses a serious safety hazard.
      • There is a plastic bag around the battery; if torn or stretched, there is no safety hazard.
      FixBotに聞いてみる
      コメントを追加
    4. Polaroid PTAB7XC Screen Replacement: 手順 4、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 4、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 4、 3の画像 3
      • Desolder the following components from the motherboard.
      • Desolder from the motherboard the red wire that connects to the speaker unit.
      • Desolder from the motherboard the black wire that connects to the speaker unit.
      • Desolder from the motherboard the gray wire that runs along the edge of the device.
      • The motherboard will now be detached from any wires connecting to the device except for those attached to the battery.
      FixBotに聞いてみる
      コメントを追加
    5. Polaroid PTAB7XC Screen Replacement: 手順 5、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 5、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 5、 3の画像 3
      この手順で使用する道具:
      • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
      • Use a small opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
      • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
      • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
      • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
      FixBotに聞いてみる
      コメントを追加
    6. Polaroid PTAB7XC Screen Replacement: 手順 6、 3の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 6、 3の画像 2 Polaroid PTAB7XC Screen Replacement: 手順 6、 3の画像 3
      • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning them counterclockwise.
      FixBotに聞いてみる
      コメントを追加
    7. Polaroid PTAB7XC Screen Replacement: 手順 7、 1の画像 1
      • Lift the motherboard and battery out of the device using your hands.
      • The back of the display and the speaker unit will now be visible and accessible
      FixBotに聞いてみる
      コメントを追加
    8. Polaroid PTAB7XC Screen Replacement: 手順 8、 1の画像 1
      • Remove the 5mm screw that holds the speaker unit on to the display unit using a J000 screwdriver, turning the screws counterclockwise.
      FixBotに聞いてみる
      コメントを追加
    9. Polaroid PTAB7XC Screen Replacement: 手順 9、 1の画像 1
      • Using thumb and forefinger, remove the speaker unit from the device
      FixBotに聞いてみる
      コメントを追加
    10. Polaroid PTAB7XC Screen Replacement: 手順 10、 1の画像 1
      • Using a J000 Philips head screwdriver, remove the two 5mm screws that hold the display unit down at the bottom of the device, turning the screws counterclockwise.
      FixBotに聞いてみる
      コメントを追加
    11. Polaroid PTAB7XC Screen Replacement: 手順 11、 1の画像 1
      • Lift the small black display protector that was between the screws and the display unit using your forefinger and thumb.
      FixBotに聞いてみる
      コメントを追加
    12. Polaroid PTAB7XC Screen Replacement: 手順 12、 1の画像 1
      • Using both hands, lift up the device.
      • Using your fingers, push upward from below on the screen until the screen and display unit pop out of the black plastic frame.
      • The screen and display unit should now be separated from the plastic casing.
      • Set the screen and display unit screen-side down.
      FixBotに聞いてみる
      コメントを追加
    13. Polaroid PTAB7XC Screen Replacement: 手順 13、 2の画像 1 Polaroid PTAB7XC Screen Replacement: 手順 13、 2の画像 2
      • Wedge the large plastic opening tool into one of the notches on the edge of the screen and display unit.
      • Pry until a small tab pops out of the notch.
      • Repeat on every notch around the edge of the screen and display unit.
      FixBotに聞いてみる
      コメントを追加
    14. Polaroid PTAB7XC Screen Replacement: 手順 14、 1の画像 1
      • Using your fingers, lift the display unit off of the screen.
      • The screen is now replaceable.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Meg Lybbert
メンバー登録日: 10/08/15
649 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-2, Plummer Fall 2015 Eastern Washington University, Team 2-2, Plummer Fall 2015人のメンバー
EWU-PLUMMER-F15S2G2
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 765
