はじめに
The rumble motor is the device that allows the move controller to vibrate. This guide will help you replace it if it is broken or damaged.
必要な工具と部品
Using a soldering iron, carefully desolder the wires from the board. For help with desoldering, please check out this guide: How To Solder and Desolder Connections
1件のガイドコメント
Step 7, there are 2 screws at the top near the white spherical piece holding the PCB on place that also need to be removed before you can lift it out
