Remove all attachments, like the water reservoir, the brewing chamber, the bean compartment lid, and the drip tray. Remove all of the coffee beans.
Turn the machine around so the back is facing you. Remove the two T10 Torx screws at the bottom edge. Pull out the back at the bottom edge and lift it down.
It's important that the parts are readily visible:
The motherboard
The pump
The flow meter
The heating element
Pull the upper cover out from under the front cover and lay it slightly offset.
Remove both of the T10 Torx screws attached to the side covers.
Picture 2 shows the grinder, which can now be easily taken off.
If you want to repair the grinder: here are the instructions Replacing the Philips ceramic grinder motor and sensor
To be on the safe side, remove the three black cables of the flowmeter from their holder so that the pump has a free path.
Pull the two flat connectors off the pump.
The thermal fuse on the cable is glued to the pump at the factory. Carefully scrape off the adhesive and pull the thermal fuse out downwards.
The rubber holder for the pump is hooked at the top. Push the rubber hook away from you with a metal spatula and leave the metal spatula in place.
Take a strong screwdriver and now push the bracket with a lot of force towards the water tank side until it gradually comes out together with the pump.
Lift out the pump. It is still connected with two hoses.
Follow the steps in reverse order to reassemble your device.
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
oldturkey03さんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
