メインコンテンツにスキップ
Philips DS3000 Speakers Replacement
必要な工具と部品
  1. Philips DS3000 Speakers Replacement, Speakers: 手順 1、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Insert an opening tool between the gray front casing and white back casing.
    • Pry the gray casing away from the white casing.
  2. Philips DS3000 Speakers Replacement: 手順 2、 1の画像 1
    • Lift the metal latch on the ZIF connector using a spudger.
    • Gently pull the ribbon away from the connector.
    • If you are unfamiliar with using connectors, consult this guide.
    • Ensure the connector’s latch is fully lifted before pulling the ribbon cable. This will prevent cable damage.
  3. Philips DS3000 Speakers Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    Phillips #1 Screwdriver
    $5.49
  4. Philips DS3000 Speakers Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • Slowly pry around the black internal housing using an opening tool.
    • Pull the loosened black lid away from the back housing.
  5. Philips DS3000 Speakers Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    $5.49
    • Locate the green circuit board on the back of the black lid.
    • Remove the four 8 mm Phillips #1 screws securing the circuit board using a Phillips #1 Screwdriver. The screws are located at the four corners of the board.
  6. Philips DS3000 Speakers Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    $5.49
    • Remove the single 8 mm Phillips #1 screw using a Phillips #1 Screwdriver.
    • Pull the speaker port (the large black tube) off the main black housing.
  7. Philips DS3000 Speakers Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    $5.49
    • Remove the four 7 mm Phillips #1 screws holding the speaker in place using a Phillips #1 Screwdriver.
    • The speaker is located under the speaker port, which you removed in Step 6.
  8. Philips DS3000 Speakers Replacement: 手順 8、 1の画像 1
    • Gently pull the speaker away from the black housing.
    • The speaker should remain connected to the housing through a pair of wires.
  9. Philips DS3000 Speakers Replacement: 手順 9、 1の画像 1
    • Carefully score an inch of the black sponge insulation with a wire cutter.
    • Gently pull the foam away from the wires.
    • A scissor, box cutter, or X-ACTO knife may be used in place of a wire cutter.
    • While cutting the foam, use gentle pressure to avoid damaging underlying wires.
  10. Philips DS3000 Speakers Replacement: 手順 10、 2の画像 1 Philips DS3000 Speakers Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    Soldering Iron 60w Hakko 503F
    $19.99
    • Record where the wires connect to the speaker. When installing a new speaker, solder the wires onto those same points.
    • Heat up the solder securing the red wire using a soldering iron.
    • Remove the red wire.
    • Remove the black wire through the same process.
    • Handle a soldering iron with extreme care to avoid serious burns. Work in a well ventilated area to avoid inhaling solder fumes.
  11. Philips DS3000 Speakers Replacement: 手順 11、 1の画像 1
    この手順で使用する道具:
    $19.99
    • Strip a quarter inch of rubber insulation from each of the speaker wires (red and black) using a wire stripper’s 0.80 mm wire gauge.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Andrew McAuliffe
メンバー登録日: 02/24/14
128 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 5-7, Lauer Spring 2014 Michigan Tech, Team 5-7, Lauer Spring 2014人のメンバー
MTU-LAUER-S14S5G7
3 メンバー
2のガイドは作成済み
1件のガイドコメント
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
araujojraa - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 26
今までの合計 3,642
