メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PDP Rematch Top Left and Right Button(s) Replacement
必要な工具と部品
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: 手順 1、 2の画像 1 PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: 手順 1、 2の画像 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
    FixBotに聞いてみる
    コメントを追加
  2. PDP Rematch Top Left and Right Button(s) Replacement: 手順 2、 2の画像 1 PDP Rematch Top Left and Right Button(s) Replacement: 手順 2、 2の画像 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
    FixBotに聞いてみる
    コメントを追加
  3. PDP Rematch Top Left and Right Button(s) Replacement: 手順 3、 2の画像 1 PDP Rematch Top Left and Right Button(s) Replacement: 手順 3、 2の画像 2
    • Gently lift off the hard cover with your hand; it should not need much force.
    FixBotに聞いてみる
    コメントを追加
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: 手順 4、 2の画像 1 PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: 手順 4、 2の画像 2
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  5. PDP Rematch Top Left and Right Button(s) Replacement: 手順 5、 2の画像 1 PDP Rematch Top Left and Right Button(s) Replacement: 手順 5、 2の画像 2
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
    FixBotに聞いてみる
    コメントを追加
  6. PDP Rematch Top Left and Right Button(s) Replacement: 手順 6、 2の画像 1 PDP Rematch Top Left and Right Button(s) Replacement: 手順 6、 2の画像 2
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
GraceGrubbs
メンバー登録日: 01/24/24
147 ポイント
1ガイドが承認済み
チーム
Tennessee Tech University, Team 1-3, Pickering Spring 2024 Tennessee Tech University, Team 1-3, Pickering Spring 2024人のメンバー
TNTECH-PICKERING-S24S1G3
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 529
