メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Orbo Jr. Speaker Replacement
必要な工具と部品
  1. Orbo Jr. Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
    FixBotに聞いてみる
    コメントを追加
  2. Orbo Jr. Speaker Replacement: 手順 2、 3の画像 1 Orbo Jr. Speaker Replacement: 手順 2、 3の画像 2 Orbo Jr. Speaker Replacement: 手順 2、 3の画像 3
    • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
    • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
    FixBotに聞いてみる
    コメントを追加
  3. Orbo Jr. Speaker Replacement: 手順 3、 1の画像 1
    • Gently pull the cables attached to the speaker to remove it from the back cover.
    • The speaker is taped in the back cover and caution should be used when pulling on the wires.
    FixBotに聞いてみる
    コメントを追加
  4. Orbo Jr. Speaker Replacement: 手順 4、 1の画像 1
    • Pull back the tape to expose the wires that are attached to the battery.
    FixBotに聞いてみる
    コメントを追加
  5. Orbo Jr. Speaker Replacement: 手順 5、 2の画像 1 Orbo Jr. Speaker Replacement: 手順 5、 2の画像 2
    • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
    • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
    • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
    FixBotに聞いてみる
    コメントを追加
  6. Orbo Jr. Speaker Replacement: 手順 6、 3の画像 1 Orbo Jr. Speaker Replacement: 手順 6、 3の画像 2 Orbo Jr. Speaker Replacement: 手順 6、 3の画像 3
    • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
    • Positive and Negative battery terminals.
    • Be careful to not make contact to other components on the motherboard while using the soldering iron.
    FixBotに聞いてみる
    コメントを追加
  7. Orbo Jr. Speaker Replacement, Speaker: 手順 7、 3の画像 1 Orbo Jr. Speaker Replacement, Speaker: 手順 7、 3の画像 2 Orbo Jr. Speaker Replacement, Speaker: 手順 7、 3の画像 3
    • Unsolder the positive and negative speaker wires from the connection on the motherboard.
    • Be careful to not make contact to other components on the motherboard while using the solder iron.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ryan Christman
メンバー登録日: 02/10/16
684 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 3-1, Sullivan Spring 2016 USF Tampa, Team 3-1, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S3G1
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 40
今までの合計 491
