はじめに
Use this guide to open your Apple Watch Series 7 for repairs.
Note: The opening procedure for the 41 mm and the 45 mm Apple Watch series 7 is the same. You can use this guide for both models.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Before starting repairs, take your watch off the charger and power it down.
この手順で使用する道具:Safety Glasses$3.19
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
Once inserted, tilt the blade to pry the display open slightly and create a gap between the screen and the watch body.
Insert an opening pick in the gap your created.
Slide the opening pick along the short edge of the watch to slice the adhesive.
Lift the display and carefully pull it towards the watch crown.
Swing the display open to an upward position.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
ある他の人がこのガイドを完成しました。
