メインコンテンツにスキップ
OnePlus Nord Battery Replacement
必要な工具と部品
  1. OnePlus Nord Battery Replacement, Loosen the rear glass adhesive: 手順 1、 1の画像 1
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. OnePlus Nord Battery Replacement, Create a gap: 手順 2、 2の画像 1 OnePlus Nord Battery Replacement, Create a gap: 手順 2、 2の画像 2
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert an opening pick into the gap.
  3. OnePlus Nord Battery Replacement, Slice the adhesive: 手順 3、 2の画像 1 OnePlus Nord Battery Replacement, Slice the adhesive: 手順 3、 2の画像 2
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during this process.
  4. OnePlus Nord Battery Replacement: 手順 4、 3の画像 1 OnePlus Nord Battery Replacement: 手順 4、 3の画像 2 OnePlus Nord Battery Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick under the bottom right corner.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
  5. OnePlus Nord Battery Replacement: 手順 5、 3の画像 1 OnePlus Nord Battery Replacement: 手順 5、 3の画像 2 OnePlus Nord Battery Replacement: 手順 5、 3の画像 3
    • Insert a third opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus Nord Battery Replacement: 手順 6、 3の画像 1 OnePlus Nord Battery Replacement: 手順 6、 3の画像 2 OnePlus Nord Battery Replacement: 手順 6、 3の画像 3
    • Insert a fourth opening pick under the top left corner.
    • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
  7. OnePlus Nord Battery Replacement: 手順 7、 2の画像 1 OnePlus Nord Battery Replacement: 手順 7、 2の画像 2
    • Insert a fifth opening pick under the bottom left corner.
    • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
  8. OnePlus Nord Battery Replacement, Remove the back cover: 手順 8、 1の画像 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. OnePlus Nord Battery Replacement, Remove the motherboard cover: 手順 9、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the ten 3.6 mm-long screws from the motherboard cover.
  10. OnePlus Nord Battery Replacement: 手順 10、 3の画像 1 OnePlus Nord Battery Replacement: 手順 10、 3の画像 2 OnePlus Nord Battery Replacement: 手順 10、 3の画像 3
    • Insert the tip of an opening pick under the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that holds the cover in its place.
    • Remove the motherboard cover.
  11. OnePlus Nord Battery Replacement, Disconnect the battery: 手順 11、 2の画像 1 OnePlus Nord Battery Replacement, Disconnect the battery: 手順 11、 2の画像 2
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  12. OnePlus Nord Battery Replacement, Remove the battery: 手順 12、 3の画像 1 OnePlus Nord Battery Replacement, Remove the battery: 手順 12、 3の画像 2 OnePlus Nord Battery Replacement, Remove the battery: 手順 12、 3の画像 3
    • Peel back the red pull tab and the black sticker from the edge of the battery.
    • Pull the tab up steadily to break up the adhesive holding the battery in place.
    • If the adhesive is too strong, place a heated iOpener on the screen for two minutes or use a heat gun to soften the adhesive beneath the battery.
  13. OnePlus Nord Battery Replacement: 手順 13、 1の画像 1
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • You can reuse the old adhesive tape in case it's still sticky. If you need to remove it, replace it with new custom cut adhesive tape.
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
48,633 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
3 件のコメント
charger plug is not working
Priya Gulati - 返信
realizan envios a Peru?
LUCHO FERNANDEZ - 返信
Thanks for the guide, just replaced battery in mine.
Radek Věchet - 返信
コメントを追加
統計データ:
過去 24時間: 40
過去 7 日: 248
過去 30 日: 1,041
今までの合計 25,079
