メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 7T Screen Replacement
必要な工具と部品
ビデオの概要
  1. OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: 手順 1、 3の画像 1 OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: 手順 1、 3の画像 2 OnePlus 7T Screen Replacement, OnePlus 7T Screen Replacement: 手順 1、 3の画像 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus 7T Screen Replacement: 手順 2、 2の画像 1 OnePlus 7T Screen Replacement: 手順 2、 2の画像 2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus 7T Screen Replacement: 手順 3、 3の画像 1 OnePlus 7T Screen Replacement: 手順 3、 3の画像 2 OnePlus 7T Screen Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus 7T Screen Replacement: 手順 4、 2の画像 1 OnePlus 7T Screen Replacement: 手順 4、 2の画像 2
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus 7T Screen Replacement: 手順 5、 3の画像 1 OnePlus 7T Screen Replacement: 手順 5、 3の画像 2 OnePlus 7T Screen Replacement: 手順 5、 3の画像 3
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    FixBotに聞いてみる
    コメントを追加
  6. OnePlus 7T Screen Replacement: 手順 6、 1の画像 1
    • Use a Phillips screwdriver to remove the 11 screws from the plastic motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  7. OnePlus 7T Screen Replacement: 手順 7、 3の画像 1 OnePlus 7T Screen Replacement: 手順 7、 3の画像 2 OnePlus 7T Screen Replacement: 手順 7、 3の画像 3
    • Use a spudger to pry up the plastic motherboard cover.
    • Remove the plastic motherboard cover.
    FixBotに聞いてみる
    コメントを追加
  8. OnePlus 7T Screen Replacement: 手順 8、 2の画像 1 OnePlus 7T Screen Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to disconnect all flex cables leading to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. OnePlus 7T Screen Replacement: 手順 9、 3の画像 1 OnePlus 7T Screen Replacement: 手順 9、 3の画像 2 OnePlus 7T Screen Replacement: 手順 9、 3の画像 3
    • Grasp the red battery tab with your fingers.
    • Pull upwards on the tab and remove the battery.
    FixBotに聞いてみる
    コメントを追加
  10. OnePlus 7T Screen Replacement: 手順 10、 3の画像 1 OnePlus 7T Screen Replacement: 手順 10、 3の画像 2 OnePlus 7T Screen Replacement: 手順 10、 3の画像 3
    この手順で使用する道具:
    • Use a pair of tweezers to grasp the end of the flex cables that were just disconnected.
    • Gently pull the cables backwards so that they remain bent back from the phone's motherboard area.
    FixBotに聞いてみる
    コメントを追加
  11. OnePlus 7T Screen Replacement: 手順 11、 2の画像 1 OnePlus 7T Screen Replacement: 手順 11、 2の画像 2
    • Use a heat gun to lightly heat the edges of the phone's screen to soften the adhesive that connects the display to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Follow the iOpener Heating guide for instructions on using the iOpener.
    FixBotに聞いてみる
    コメントを追加
  12. OnePlus 7T Screen Replacement: 手順 12、 3の画像 1 OnePlus 7T Screen Replacement: 手順 12、 3の画像 2 OnePlus 7T Screen Replacement: 手順 12、 3の画像 3
    • Apply a suction cup to the lower portion of the phone's display and pull firmly to create a crack between the screen and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the phone's display.
    FixBotに聞いてみる
    コメントを追加
  13. OnePlus 7T Screen Replacement: 手順 13、 2の画像 1 OnePlus 7T Screen Replacement: 手順 13、 2の画像 2
    • Carefully remove the phone's display.
    • A flex cable is still attached to the back of the phone's display. Make sure the cable does not become caught when removing the display.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Selena
メンバー登録日: 12/15/19
2,944 ポイント
14のガイドは作成済み
1件のガイドコメント
There needs to be steps on how to reseal the device after the replacement.
Asd - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 38
過去 30 日: 135
今までの合計 14,150
