メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 6T Front Camera Replacement
必要な工具と部品
  1. OnePlus 6T Front Camera Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus 6T Front Camera Replacement: 手順 2、 1の画像 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus 6T Front Camera Replacement: 手順 3、 1の画像 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus 6T Front Camera Replacement: 手順 4、 3の画像 1 OnePlus 6T Front Camera Replacement: 手順 4、 3の画像 2 OnePlus 6T Front Camera Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus 6T Front Camera Replacement, Front Camera: 手順 5、 2の画像 1 OnePlus 6T Front Camera Replacement, Front Camera: 手順 5、 2の画像 2
    この手順で使用する道具:
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
    FixBotに聞いてみる
    コメントを追加
  6. OnePlus 6T Front Camera Replacement: 手順 6、 1の画像 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
    FixBotに聞いてみる
    コメントを追加
  7. OnePlus 6T Front Camera Replacement: 手順 7、 1の画像 1
    • Using a spudger, gently remove the midframe and place it to the side.
    FixBotに聞いてみる
    コメントを追加
  8. OnePlus 6T Front Camera Replacement: 手順 8、 1の画像 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
107,779 ポイント
270のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
28,230のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 54
今までの合計 1,785
