はじめに
If your OnePlus 6T back cover is damaged or scratched, it may be time to replace it to ensure the battery is protected adequately. Follow this simple guide to remove the back cover.
必要な工具と部品
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
17 の人々がこのガイドを完成させました。
3 件のコメント
I wonder if this is the same for OnePlus 6 (6000/6003)?
Thanks for this guide. But is there something particular after removing the old piece to install the new one ? How the new one will be glued ?
