メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus 6 Rear Camera Replacement
必要な工具と部品
  1. OnePlus 6 Rear Camera Replacement, Back Panel: 手順 1、 1の画像 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus 6 Rear Camera Replacement: 手順 2、 2の画像 1 OnePlus 6 Rear Camera Replacement: 手順 2、 2の画像 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus 6 Rear Camera Replacement: 手順 3、 2の画像 1 OnePlus 6 Rear Camera Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus 6 Rear Camera Replacement, Battery: 手順 4、 2の画像 1 OnePlus 6 Rear Camera Replacement, Battery: 手順 4、 2の画像 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus 6 Rear Camera Replacement, Fingerprint sensor: 手順 5、 2の画像 1 OnePlus 6 Rear Camera Replacement, Fingerprint sensor: 手順 5、 2の画像 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
    FixBotに聞いてみる
    コメントを追加
  6. OnePlus 6 Rear Camera Replacement, Motherboard: 手順 6、 1の画像 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  7. OnePlus 6 Rear Camera Replacement: 手順 7、 2の画像 1 OnePlus 6 Rear Camera Replacement: 手順 7、 2の画像 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
    FixBotに聞いてみる
    コメントを追加
  8. OnePlus 6 Rear Camera Replacement, Rear Camera: 手順 8、 2の画像 1 OnePlus 6 Rear Camera Replacement, Rear Camera: 手順 8、 2の画像 2
    • Lift up on the small tabs connecting the cameras to the motherboard to disconnect them.
    • Push on the lens side of the cameras and remove them from the motherboard.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Hunter Brown
メンバー登録日: 09/28/21
118 ポイント
1ガイドが承認済み
チーム
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021人のメンバー
CLEM-HUNTER-F21S4G3
5 メンバー
20のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 52
今までの合計 1,710
