メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnHub Outer Casing Replacement
必要な工具と部品
    1. OnHub Outer Casing Replacement, Speaker Grille: 手順 1、 2の画像 1 OnHub Outer Casing Replacement, Speaker Grille: 手順 1、 2の画像 2
      • Make sure the device is unplugged before proceeding with the disassembly.
      • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
      FixBotに聞いてみる
      コメントを追加
    2. OnHub Outer Casing Replacement: 手順 2、 1の画像 1
      • Place the plastic opening tool under the speaker grille, and just above the light ring.
      • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
      FixBotに聞いてみる
      コメントを追加
    3. OnHub Outer Casing Replacement: 手順 3、 2の画像 1 OnHub Outer Casing Replacement: 手順 3、 2の画像 2
      • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
      • There is a delicate wire connection to the antenna that is easily broken if not careful.
      FixBotに聞いてみる
      コメントを追加
    1. OnHub Outer Casing Replacement, Congestion-sensing Antenna: 手順 4、 2の画像 1 OnHub Outer Casing Replacement, Congestion-sensing Antenna: 手順 4、 2の画像 2
      • Remove the wire connection to the antenna by soldering it off.
      • For help with soldering and de-soldering check out the iFixit Soldering Guide
      FixBotに聞いてみる
      コメントを追加
    1. OnHub Outer Casing Replacement, Outer Casing: 手順 5、 2の画像 1 OnHub Outer Casing Replacement, Outer Casing: 手順 5、 2の画像 2
      • You must remove the plastic cover found just above the speaker.
      • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
      • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
      • Though the snapping noise is normal, take care not to break these clips.
      FixBotに聞いてみる
      コメントを追加
    2. OnHub Outer Casing Replacement: 手順 6、 1の画像 1
      • Upon removing the cover, four screws and the speaker housing will be exposed.
      • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
      • This unlocks the speaker housing and antenna array from the casing.
      FixBotに聞いてみる
      コメントを追加
    3. OnHub Outer Casing Replacement: 手順 7、 2の画像 1 OnHub Outer Casing Replacement: 手順 7、 2の画像 2
      • On the bottom of the OnHub is two screws holding the casing to the base.
      • To access these screws, you must remove the rubber pad that is glued to the base.
      • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
      • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
      • The rubber pad is thin and fragile; be careful not to tear when removing.
      FixBotに聞いてみる
      コメントを追加
    4. OnHub Outer Casing Replacement: 手順 8、 1の画像 1
      • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
      FixBotに聞いてみる
      コメントを追加
    5. OnHub Outer Casing Replacement: 手順 9、 2の画像 1 OnHub Outer Casing Replacement: 手順 9、 2の画像 2
      • Once the two screws are removed from the base, it is time to split the casing apart.
      • It is okay if a couple clips break. It will still hold together with a few remaining.
      • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
      • There are three hooking style clips in total.
      FixBotに聞いてみる
      コメントを追加
    6. OnHub Outer Casing Replacement: 手順 10、 1の画像 1
      • Once unclipped, you can slide the two casing halves apart, and remove the casing.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Joseph Ainsworth
メンバー登録日: 02/10/16
544 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-3, Sullivan Spring 2016 USF Tampa, Team 3-3, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S3G3
3 メンバー
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 706
