メインコンテンツにスキップ
Nintendo Switch Right Joy-Con Rail Replacement
必要な工具と部品
  1. Nintendo Switch Right Joy-Con Rail Replacement, Release the Joy Con controller locking tabs: 手順 1、 3の画像 1 Nintendo Switch Right Joy-Con Rail Replacement, Release the Joy Con controller locking tabs: 手順 1、 3の画像 2 Nintendo Switch Right Joy-Con Rail Replacement, Release the Joy Con controller locking tabs: 手順 1、 3の画像 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Right Joy-Con Rail Replacement, Remove the Joy Con controllers: 手順 2、 3の画像 1 Nintendo Switch Right Joy-Con Rail Replacement, Remove the Joy Con controllers: 手順 2、 3の画像 2 Nintendo Switch Right Joy-Con Rail Replacement, Remove the Joy Con controllers: 手順 2、 3の画像 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Right Joy-Con Rail Replacement, Remove the back-side screws: 手順 3、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Right Joy-Con Rail Replacement, Remove the top and bottom screws: 手順 4、 2の画像 1 Nintendo Switch Right Joy-Con Rail Replacement, Remove the top and bottom screws: 手順 4、 2の画像 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Right Joy-Con Rail Replacement: 手順 5、 2の画像 1 Nintendo Switch Right Joy-Con Rail Replacement: 手順 5、 2の画像 2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Right Joy-Con Rail Replacement: 手順 6、 2の画像 1 Nintendo Switch Right Joy-Con Rail Replacement: 手順 6、 2の画像 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Right Joy-Con Rail Replacement: 手順 7、 1の画像 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Right Joy-Con Rail Replacement: 手順 8、 3の画像 1 Nintendo Switch Right Joy-Con Rail Replacement: 手順 8、 3の画像 2 Nintendo Switch Right Joy-Con Rail Replacement: 手順 8、 3の画像 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Right Joy-Con Rail Replacement, Remove the shield plate: 手順 9、 1の画像 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the six 3 mm screws securing the shield plate to the device.
  10. Nintendo Switch Right Joy-Con Rail Replacement: 手順 10、 2の画像 1 Nintendo Switch Right Joy-Con Rail Replacement: 手順 10、 2の画像 2
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
  11. Nintendo Switch Right Joy-Con Rail Replacement: 手順 11、 3の画像 1 Nintendo Switch Right Joy-Con Rail Replacement: 手順 11、 3の画像 2 Nintendo Switch Right Joy-Con Rail Replacement: 手順 11、 3の画像 3
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • You can reuse the pink thermal compound if you're careful. Keep the compound clean and make sure it makes solid contact between the heat sink and the shield during reassembly.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  12. Nintendo Switch Right Joy-Con Rail Replacement, Right Joy-Con Rail: 手順 12、 2の画像 1 Nintendo Switch Right Joy-Con Rail Replacement, Right Joy-Con Rail: 手順 12、 2の画像 2
    • Use a spudger to flip up the small gray locking flap on the right Joy-Con rail ribbon cable ZIF connector.
  13. Nintendo Switch Right Joy-Con Rail Replacement: 手順 13、 1の画像 1
    • Remove the four 3.8mm JIS #0 screws from the right Joy-Con rail.
  14. Nintendo Switch Right Joy-Con Rail Replacement: 手順 14、 1の画像 1
    • Remove the right Joy-Con rail.
終わりに
71 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Blake Klein
メンバー登録日: 01/29/17
70,537 ポイント
50のガイドは作成済み
13 件のコメント
Would you happen to know how to take out the screws if they’ve been stripped due to corrosion/rust? The back and site plate screws seem to have corroded and started to strip when I tried to unscrew them.
MrColorless - 返信
I am running into same problem now. 3 out of 4 back screws are striped
Ryan Kindle -
Same issue for me as well, my husband pretty much just brute strengths through them for me until I can get replacement screws. Not the most sophisticated method, but effective.
Sidney Parson -
This was a wonderful guide. Its straight forward, simple to understand, and doesnt pass over any steps large or small. Thank you to your team for what you do for us all.
Nicholas Bell - 返信
what can i do if the bracket has snapped off of the consel?
and where could i purchase replacement parts
joe mama - 返信
コメントを追加
統計データ:
過去 24時間: 47
過去 7 日: 461
過去 30 日: 2,222
今までの合計 131,021
