メインコンテンツにスキップ
Nintendo 3DSのWi-Fiアンテナの交換
必要な工具と部品
  1. Nintendo 3DSのWi-Fiアンテナの交換, バックカバー固定ネジを緩める: 手順 1、 1の画像 1
    この手順で使用する道具:
    Phillips #00 Screwdriver
    $5.49
    • PH00プラスドライバーを使って、バックカバーの上部に沿って留められている4本のネジを緩めます。
    • このコンソールに使用されているネジはすべてJISネジです。 公式 iFixit PH000-PH1 プラスドライバーはJISネジに対応するように設計されていますので、安全にお使いいただけます。iFixit公式ドライバーまたはJISドライバー以外のドライバーを使用すると、ネジ頭の溝を舐める可能性があります。
    • ネジはロックワッシャーで固定されており、バックカバーから外れることはありません。
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - 返信
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - 返信
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - 返信
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - 返信
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - 返信
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - 返信
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - 返信
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - 返信
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - 返信
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - 返信
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - 返信
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - 返信
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - 返信
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
    It's JIS #00
    It's not the same thing
    Alstein Einbert - 返信
    To all the people that seem to think it's ok to tell people to use a phillips
    A PHILLIPS WILL damage the head of a JIS screw.
    The middle is thicker, which breaks the inner corners and the angle is less extreme causing it to slip out
    The extra pressure you add is to break that screw into a "phillips-ier" shape
    A newbie will still slip out and risk stipping the scew
    Btw you don't need to press hard with a JIS driver in a JIS screw
    If you don't know what you are doing, please refrain from editing this
    "All screws in this device are JIS screws. All official iFixit Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws."
    - dude who doesn't know anything
    Hi Alstein!
    You're right about most Phillips screwdrivers damaging JIS screws, but our Phillips bits (#000–1) are designed to be compatible with JIS of that size. We can't guarantee that Phillips drivers from other manufacturers are also cross compatible. We added the aforementioned bullet as a clarifier for this difference.
    Alex Diaz-Kokaisl -
    Hi Alex
    The bit still slips out easier due to the less extreme vertical angle, causing someone inexperienced to damage their screws.
    I and the Nintendo Homebrew community (talking about the hardware repair part of it) believe that even if it's true that the bit is shaped to cause less damage its completly wrong to tell someone to use the wrong bit as we get both people who ask "this bit is JIS friendly right" on normal phillips screwdrivers and people who come crying that they stripped their screws and have 0 idea why everyday so we know for a fact people are taking these kind of messages the wrong way.
    I believe the message i am putting is important as it tells the user the bits are different, tells them what to do if they don't have a JIS screwdriver and the damage its gonna cause.
    I'd agree to add a bullet that clarifies that ifixit phillips screwdrivers are designed to cause less damage under our disclaimer, not to just say phillips is fine to use on JIS
    Alstein Einbert -
    why is this guide telling you to use a Phillips screwdriver on a JIS
    this is just wrong
    "All screws in this device are JIS Screws, Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screw" wtf is this
    so you are saying that
    1. ifixit's phillips bit is a JIS because yes a JIS will work fine in a phillips screw, not vice versa.
    2. "use a ifixit phillips screwdriver that's the right screwdriver" instead of the jis one they might already have EVEN MAYBE FROM IFIXIT.
    yeah you mention in passing "or you could use a JIS Screwdriver but you should be mentioning in passing that ifixits phillips is ji-... ahem... i mean is compatible with jis screws
    this is absolutely stupid. Add that with the lack of care for looking for selling long lasting products like batteries and the lower quality of the recent bits i think ifixit is at its end.
    Daninator - 返信
    "i think ifixit is at its end." not in any way overdramatic at all
    FarmYard Gaming -
  2. Nintendo 3DSのWi-Fiアンテナの交換, バックカバーの取り外し: 手順 2、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, バックカバーの取り外し: 手順 2、 2の画像 2
    • 片手でデバイスを掴み、裏返します。
    • カバーが元の位置に戻らないようにもう片方の手でバックカバーの上端を掴みます。
    • バックカバーが表になるようもう一度3DSを裏返します。
    • バックカバーを引き上げ、デバイス本体から取り外します。
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - 返信
  3. Nintendo 3DSのWi-Fiアンテナの交換, バッテリー: 手順 3、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, バッテリー: 手順 3、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換, バッテリー: 手順 3、 3の画像 3
    • バッテリーと底部ケースの隙間にプラスチックの開口ツールを差し込みます。
    • プラスチック製開口ツールを使って、バッテリーを持ち上げます。
    • バッテリー上部の端をつかみ、底部ケースから持ち上げます。
  4. Nintendo 3DSのWi-Fiアンテナの交換, 底部ケース: 手順 4、 1の画像 1
    • JIS#00プラスドライバーを使って、下部ケースから長さ6.3mmの黒ネジ9本を外します。
    • JIS(日本産業規格)のプラスネジは(アメリカ等の国で一般的な)フィリップス規格のプラスネジとは異なります。これらのネジ頭を舐めないようにするには、フィリップス規格の#00ドライバーではなく、JIS#00ドライバーを使用していることを確認してください。フィリップス規格の#00ドライバーでも下方向に強い力をかければ使用できますが、ネジの頭が変形して、ネジ頭を舐めてしまう恐れがありますのでご注意ください。
    • iFixitのフィリップス規格プラスドライバーは、JIS頭のネジの損傷を軽減するように設計されていますので、使用しても問題ありませんが、より強い力を加えてください。iFixitの公式プラスドライバー以外について、このような配慮がされているかは分かりません。
    • JIS#00ドライバーで、ゲームカートリッジスロットの上にある長さ2.4mmの銀色のネジ1本を外します。
    Had to give up at this point. Tried using the ifixit #00 phillips screwdriver to take out two screws and ended up stripping them.
    Demios - 返信
    Stuck at the same spot, those screws are in there really tight.
    John Pasula - 返信
    Ruined my screws because of incorrect head, thanks!
    3dsuser - 返信
    I had so much trouble with these screws, I gave up. Unfortunately, I can't accept failure so tried again. I figured out if you turn it right before you loosen it worked. Maybe it was just me, but I turned it right then kept pressure as I turned to loosen. I was surprised I hadn't stripped any screws out.
    Nicole Bauer - 返信
    Does anyone have any idea of how to remove these screws. I've pretty badly stripped the screws and I've gone to 20+ pages trying to figure this. I'm considering just prying the !@#$ thing.
    Vino - 返信
    use a dremil and make it a flat head
    Ralph Prowant -
    ruined my screws here too...what the !@#$ nintendo?
    trying to survive a nuclear meltdown inside the !@#$ thing
    Hamza Jarkas - 返信
    More like trying to subtly enforce planned obsolescence by not allowing you to make repairs to your device.
    Ullyssys -
    I used a #00 Philips 1/8" bit with no problem; however, the narrow diameter of the counter sunk hole can inhibit making secure contact with the screw head. You can be using the right bit (#00) but if the diameter of the bit shaft is too big you won't get proper contact.
    I found this to be an excellent guide. Thanks
    Dave W - 返信
    Unscrewed the nine 6.3 mm screws using the J000 bit from the iFixit 54 bit driver kit without much effort & without stripping the screw heads. Just gotta really position the bit correctly on the screw to have a proper fitting & not strip the screw heads.
    STZ9 - 返信
    The screws didn't strip but the philips screw driver did? @__@
    These are rough either way.
    John Zhou - 返信
    I used a "Whia 273 - PH000x40" screwdriver and held it firmly pushing the palm of my hand on the yellow end of the screwdriver and rocked the screw slightly (counter clockwise and clockwise) until it started to move. Then, without letting up on the pressure I carefully backed it out. The screwdriver is excellent because it is hardened (unlike some cheapo's out there) and the very tip is blunt not sharp. If the tip is too sharp, the point will bottom out in the screw and the sides that do all the work, won't be able to fully contact the inside of the screw. This screwdriver fits so well that the screws actually stick to it once they are removed. If the screwdriver moves AT ALL when you initially try it in the screw, STOP and find a better one. Also, start with the screws in the center, somehow they seem a little easier until you get the feel for it.
    Paul -
    Push down hard and turn counter-clockwise, or push down and rotate 3DS counter-clockwise until screw is loose.
    Jonathan - 返信
    Had the exact same problem, even tried the #000 screw driver too. Stripped the screws due to how tightly they are screwed in there and how easy they strip. I am now unsure what to do from here or if all I can do is give up.
    Sean Baldwin - 返信
    I second the one who suggested the Whia 273 PH000x40 screwdriver. I had a terrible time unscrewing these screws, and almost stripped them using a cheaper #000 screwdriver. Also tried a 3/16" flathead and destroyed the screwdriver. I bought the Whia and glad I did. It fit perfectly and did not slip at all. DEFINITELY recommend purchasing this high-quality screwdriver. Cost about $10 but well worth it to avoid the hassle.
    pbrazis - 返信
    The best way I found that works quite well, if you find a screwdriver or bit that is good enough: hold the screwdriver or bit with tons of pressure, and rotate the 3DS clockwise! It will come out in 5-6 rotations, you can do this step in about 10 minutes this way (put down a cloth first, don't scratch the front!)
    Gannon Trueman - 返信
    I HAVE A WAY TO GET OUT THE STRIPED SCREW. Like you, I had screwed up and tried everything to get the screw out. Do NOT try the glue in that tiny hole, you will get the screw glued permanently in there. The rubber band doesn't work in that tight space either. As desperate as I was, I was trying anything from nail polish to cramming the screw driver in as hard as I possible could. Until I realized that I had a drill. Yes, with the smallest head, I drilled into the screw a little bit, messed with the part I was trying to get out, drilled a little more, messed around, and then finally on my last attempt, I had successfully drilled off the top of the screw rendering the part free. It doesn't matter which drill you use as long as you can fit the head into the hole. Then drill forward like you are trying to drill a hole through wood. Now the only problem is that the remainder of the screw will be stuck in its place. All you really have to do is get a set of pliers and twist that puppy out. And there you go!
    YuuChan - 返信
    Most likely though, if you have all the other screws out and only have one striped screw, the part should just pop off and you wouldn't have to drill the entire head off the screw.
    YuuChan - 返信
    Got a brand new #00 screw drive and it striped the first time used it. So now I'm using eyeglass repair kit screw driver and it lasts longer that the one I got of of eBay.
    And I tried all of those tactics that people have been giving and none of them are working.
    The wiha 273 PH #000×40 unsrews it easily! It has a magnet on it!
    Najee - 返信
    I’m cant get these %#*@ screws out i want to die…
    FRØSTBIT3 - 返信
    Oh god, someone help i can’t get them out.
    Mark LaPierre - 返信
    omg everyone is struggling in here smh. I used my PH000 screwdriver made sure it went in aligned to the screws and applied pressure while turning counterclockwise. once it started the screw started lifting i stopped applying pressure and they lifted beautifully. saved damaging my screws with this technique. I also used the same screwdriver size to remove the orange screw where the game slot is. Yall are welcome lol
    Evelyn Avalos - 返信
    USE A DIFFERENT SCREWDRIVER.
    I was stuck on this for an hour. If your screwdriver is very thin, you won't get the grip necessary if your screws are on tight. I thought my screws were stripped but I switched to a bigger screwdriver and it was effortless. Just MAKE SURE IT IS A 00 PHILLIPS HEAD.
    brendon - 返信
    Use a JIS screwdriver, not Phillips! I bought the recommended screwdriver from this website and couldn't remove any screws. I went and purchased a J00 screwdriver and removed them quickly.
    danielle - 返信
    I used what I believe is a 1.5mm screwdriver which I received in one of those 60 in 1 precision screwdriver sets. It fit perfectly and much more snugly compared to any of the J0 - J000 bits.
    Andrew - 返信
    You should change the Screwdriver Type used. A Philipshead can damage Screws and/or Console. Use JIS Type-J00, which iFixIt sells, yes.
    J022 - 返信
    Lmao I've been using a Philips #00 for years and not known it was the wrong type. I ended up being fine here every time, a magnetic head helps. It's actually almost satisfying getting these ones out.
    using a J00 head. no luck at first (that's why i'm here lol) read one comment here saying turn a little bit clockwise and then try to unscrew and that did the trick!
    also, held the console with one hand and the screwdriver with the other for applying pressure but not to much or at least to grab the other side of the pressured place instead of letting the hinge press against the table.
    Thomas - 返信
  5. Nintendo 3DSのWi-Fiアンテナの交換: 手順 5、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 5、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 5、 3の画像 3
    • 3DSの他の部分から底部ケースの下端を持ち上げて外します。
    • 2本のリボンケーブルがまだマザーボードをケースに接続しているので、底部ケースを完全に引き離さないようにしてください。
    • プラスチック製開口ツールを使い、マザーボード上のソケットからショルダーボタンのリボンケーブルを取り外します。
    • デバイスから底部ケースを取り外します。
    When assembling, make sure that L ribbon is inside the case and R ribbon is not under the aluminium battery case. I got them both cut accidentally and had to replace :(
    Marek Jakóbiak - 返信
    Man muss die Folienkabel für die Tasten nicht unbedingt abziehen wenn man einen Gegenstand dahinter stellt, an dem man den Deckel senkrecht anlehnen kann.
    Jean - 返信
    Don't listen to the german guy. It's very easy to pop back
    Bruno N - 返信
  6. Nintendo 3DSのWi-Fiアンテナの交換, スライドパッドジョイスティック: 手順 6、 1の画像 1
    • スライドパッドの裏をマザーボードに固定している7.7mmプラスネジを2本外します。
    my screws wont stop spining what to i do? i have the same problem with other screws and this leavs my joystick very loss and it is dificult to muve it becuase it is aganst the case not lifted up? any sugestions? (sorry for my bad speling jaja im very bad at speling..)
    AppleTopic - 返信
    I think you stripped your screws. I think the best solution is to change the upper cover of the lower assembly and the screws. The fastest, but temporarily is to stick in some way the joystick housing to the cover, but it won’t last long, so do this only if you have to use your console while you wait the cover to come. Anyway, so not overtighten the new screws, or you will be in the same situation once again.
    Daniele Carminati -
  7. Nintendo 3DSのWi-Fiアンテナの交換: 手順 7、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 7、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 7、 3の画像 3
    • スパッジャーの平面側先端を使って、マザーボードからスライドパッドの裏面を持ち上げて外します。
    • マザーボードからスライドパッドジョイスティックを持ち上げて、リボンケーブルコネクタにアクセスできるよう裏面を下にして置きます。
    When reassembling verify that the circle pad control is oriented right. I had to go back in after completion when I realized it wasn't centered.
    Daniel Johnson - 返信
    I would not disable the back side all the way because it could really mess up your 3DS.
    masterspeggy3 - 返信
    From this step, follow this video https://youtu.be/XGdRim2Mvrk?t=627
    you can skipp from step 8 to 20
    lots of unnecessary steps
    Bruno N - 返信
  8. Nintendo 3DSのWi-Fiアンテナの交換: 手順 8、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 8、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 8、 3の画像 3
    • スパッジャーの平面側先端や指の爪を使って、スライドパッドリボンケーブルのZIFソケットの固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。
    • マザーボードからスライドパッドジョイスティックを持ち上げて外します。
    Can you replace a zif socket? The little metal pieces on mine broke off...
    Colton Alverson - 返信
    YOUR &&^&@@ HAHAHAAHA, no you cant you would have to purchase a new motherboard i feek you bro happened in my first time
    vrobinson -
    you might want to find someone who is skilled in component level microsoldering for that
    Samuel Martin -
    The retaining flap on mine broke off, is there any way to fix it?
    Madi Hansen - 返信
    Don't do this step! it is not necessary. you can skip steps 8 through 20
    S Maduras - 返信
    Skip steps 8 through 20. It will save a lot of time. Thanks S Maduras for the warning.
    clarissa.vetintegral - 返信
    Thanks S Maduras! Your tip
    made this super easy. No need for steps 8-20.
    Carl Vero -
    OH MY GOD THANK YOU SO MUCH!!!! I'm sure I would have destroyed my ds if I did all that
    Amber Selley -
    Just like everyone else I recommend skipping to step 21. You don't need to take all the components out to replace the circle pad.
    Callum M. - 返信
    Skip steps 8-20 like they said!! Doing all those unnecessary steps wasted so so much time and frustrated me hugely by causing me to damage my microphone ribbon cable…
    Falcon - 返信
    What do you mean by skipping 8-20? Do I not need to remove the screws in order to replace the lower LCD?
    Marion Saga -
    you know, after you disconnect the ribbon from the mobo, you can just remove the back discs and the rubber part. no need to go past here.
    TruGoose - 返信
  9. Nintendo 3DSのWi-Fiアンテナの交換: 手順 9、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 9、 2の画像 2
    • 作業中、スライドパッドジョイスティックの下についている2つの薄いパッドを紛失しないように、ここで取り出します。
    • スパッジャーやドライバーを使って、デバイスからパッドを持ち上げて外します。
    When reassembling, you can use the pointy end of the spudger to align the hold again with the joystick. It’ll probably have bounced around while you’re moving other things.
    anthonyhersey - 返信
    If your only goal is to replace the circle-pad, the following steps are unnecessary. You can skip to step 21, the removal of the circle-pad.
    Andrew - 返信
  10. Nintendo 3DSのWi-Fiアンテナの交換, SDボード: 手順 10、 1の画像 1
    • SDボードをマザーボードに固定している4.5mmプラスネジを2本外します。
  11. Nintendo 3DSのWi-Fiアンテナの交換: 手順 11、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 11、 2の画像 2
    • スパッジャーの平面の先端を使い、SDボードのリボンケーブルのコネクタをマザーボードのソケットからてこの原理で取り外します。
  12. Nintendo 3DSのWi-Fiアンテナの交換: 手順 12、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 12、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 12、 3の画像 3
    • SDボードとマザーボードの隙間にスパッジャーの平らな方の先端を差し込みます。
    • ゆっくりとこじり上げて、SDボードをその下にあるRFシールドから外してください。ここでこじるのが速すぎると、シールド自体やシールドの接合部を破損する恐れがあります。
    • SDボードの側面に沿って、スパッジャーを動かし、SDボードを留めている接着パッドを剥がします。
    • 一度完全に剥がされたら、マザーボードからSDボードを垂直に持ち上げて外します。
    be careful on this step, the sd card board is adhered to the rf shield below it, and bay result in the shield becoming bent as it is only soldered on one side. pry from the side of the board facing the cartridge slot.
    alex chargeer - 返信
    I didnt notice that and I broke the solders here :(
    Tony Greco -
    mine came off will this make the system not power on or make somthing not work? what do i do know?
    AppleTopic - 返信
    What did come off? the sd card reader board, or the shield mentioned in the above comment?
    Daniele Carminati -
    When putting it all back together, its easier to put the ribbon connector on before laying on the SD board.
    Pepper - 返信
    The adhesive sticker between the RF shield and the SD slot got mauled quite badly as I separated them, will this turn out to be a problem later?
    Nico - 返信
  13. Nintendo 3DSのWi-Fiアンテナの交換, Wi-Fiボード: 手順 13、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, Wi-Fiボード: 手順 13、 2の画像 2
    • Wi-Fiボードの角の下にスパッジャーの平面側の先端をスライドさせ、Wi-Fiボードをマザーボードから持ち上げます。
    • Wi-FiアンテナケーブルがWi-Fiボードにまだ接続されているので、Wi-Fiボードを完全に取り外すことはまだできません。
  14. Nintendo 3DSのWi-Fiアンテナの交換: 手順 14、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 14、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 14、 3の画像 3
    • マザーボードからWi-Fiボードを持ち上げて、底部が上向きになるまで回転させます。
    • スパッジャーの平面側先端を使い、Wi-FiボードのソケットからWi-Fiアンテナケーブルのコネクタを外します。
    • デバイスからWi-Fiボードを取り外します。
    That moment you bought all your supplies and realise while removing the wifi chip the antenna is not plugged in because you forgot to plug it in last time……… Scew me…
    Sidney the wolf - 返信
  15. Nintendo 3DSのWi-Fiアンテナの交換, マザーボードアセンブリ: 手順 15、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, マザーボードアセンブリ: 手順 15、 2の画像 2
    この手順で使用する道具:
    • マイクのそばにあるマイクのリボンケーブルをピンセットでつまみます。
    • マイクを上部ケースから垂直に引き上げます。
  16. Nintendo 3DSのWi-Fiアンテナの交換: 手順 16、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 16、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 16、 3の画像 3
    • スパッジャーの平面側先端や指の爪を使って、スピーカーアセンブリのリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。ソケットやケーブルを損傷させると、電源ボタンを押したときに電源LEDが点滅するだけになってしまいます。ご注意ください。
    • ピンセットを使って、スピーカーアセンブリのリボンケーブルの接続を外します。
    Can there be a guide on how to replace this part? I pry on the socket accidentally.
    im just a Ordinary marker - 返信
    I don't even know where they sell a new socket for this, but you'd need to have a soldering station and know how to micro solder. assuming no pads where ripped off then you'd just solder it back down. if a pad broke then you'd need to run jumpers to fix it. in short its very difficult and expensive to fix unless you have the know how and the tools already.
    ssanchez7610 -
  17. Nintendo 3DSのWi-Fiアンテナの交換: 手順 17、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 17、 2の画像 2
    • スパッジャーの平面側先端や指の爪を使って、カメラリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • 再度組み立てる際は、ゴールドの接点がマザーボード側に面しているか確認してください(カメラケーブルのゴールドの接点と反対側を向いています)。
    Be sure to fit the motherboard inbetween the joystick and volume slider in properly (you can double check by seeing if the volume slider on the outside goes up and down smoothly). When I closed it the first time it was stuck on full volume so I needed to go back in and readjust!
    Veronika Todd - 返信
    When putting the cable back I recommend to open the 3ds while keeping it face down so the cable has more room to fit.
    Roberto Cantu - 返信
    Thank you so much, opening the 3ds is needed to fit the cable back easily.
    Halefall -
    The camera ribbon cable contacts face towards the motherboard, the speaker ones face away.
    Nyuku - 返信
    skipped this step, didn't take the mobo out and continued from step 21
    Thomas - 返信
  18. Nintendo 3DSのWi-Fiアンテナの交換: 手順 18、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 18、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 18、 3の画像 3
    • マザーボードを上部ケースに固定している次の7本のプラスネジを外します。
    • 2.5mmネジ(ゴールド) 4本
    • 3.5mmネジ(黒) 2本
    • 2.5mmネジ(シルバー) 1本
    • このネジを外すと、ボリュームスライダーが落ちることがあります。
    • 3DSの底部端にあるマザーボードの片側を持ち上げます。
    Do yourself a favor and DON'T remove the 2.5 mm silver screw (yellow circle). It just holds in a little plastic bit under the volume control. The board comes out just fine with the screw still in. If you remove it, the plastic bit will fall out at random when you turn over the case.
    First time I took mine apart, I noticed something fall out later, tracked it down and then puzzled over what it was and where it came from.
    Chupi - 返信
    There is some adhesive where the AC adapter plugs in so I recommend watching out for that
    Devin Stephenson - 返信
    LISTEN TO CHUPI seriously that is such a pain to get back in
    NyxNullify - 返信
  19. Nintendo 3DSのWi-Fiアンテナの交換: 手順 19、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 19、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 19、 3の画像 3
    • 続けて、マザーボードアセンブリを持ち上げ、回転させてデバイス本体の隣に置きます。
    • スパッジャーの平面側先端や指の爪を使って、LCDリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。ソケットやケーブルを破損すると、3DSのトップ画面が機能しなくなります。
    Reinserting this ribbon cable is quite difficult. I found opening the case so that it sits upright at a 90 degree angle helps. The first two times I tried reassembling the top display did not work. Turned out that I was not inserting the ribbon cable in enough. I used tweezers to push this in by gently grabbing the ribbon cable. I was continually inspecting the cable for damage but apparently did not damage it. If anyone has a better idea on how to reinsert this cable I think others would greatly appreciate it.
    pbrazis - 返信
    Putting the cable back in is the hardest part out of all of this (if you can get past the screws near the beginning). If you have a friend that you trust very much and is very gentle, another pair of hands here really will help. If you're without a friend, make sure to use some flat, angled precision tweezers to push the ribbon in with one hand (pointed tweezers will do in a pinch but you'll have to be careful - I put a small dent in the ribbon and thought I'd broke it), and then use a spudge or something in the other to push the flap down.
    Also worth noting is that the ribbon for the top screen also handles the 3D - if you complete the guide and find you are unable to turn the 3D effect off, you didn't insert the ribbon enough, as I had the problem and re-inserting the ribbon fully fixed it.
    malcolmdemaggio - 返信
    Careful when reassembling -- watch the position of the black wifi antenna wire! I got mine most of the way back together and noticed it wouldn't close all the way. This wire had come out of the little posts holding it in place and was wedged between the screen and motherboard. Now I have to take it all apart again to fix this.
    Also if you're taking the board out of a working unit to get at the CLK signal to backup the NAND chip ("hardmod"), you don't need to remove the difficult ribbon cable in this step, or the other two wide ones at the top right from earlier. Leave them attached and swing the board out. It won't rotate a full 180 degrees to sit flat outside the unit, but you can open the screen 90 degrees to prop the rest up while having the board out on your table.
    Chupi - 返信
    I recommend not taking it off in the first place, as reattaching it is awfully difficult. You can easily clean out your abxy buttons with it still attached
    Martin - 返信
    I am having problems re-inserting the three ribbon cables (3DS XL). Do you need to flip up the retaining flaps first? (I just pulled them out of the slots when removing them.
    darren.brundell - 返信
    if the flap for the ribbon cable breaks what do you do
    lionmine ____ - 返信
    who else felt really proud after finally reinserting the cable
    Harrison Rigg - 返信
    The easiest way to get that ribbon back in is to hold it with some reverse tweezers that I fix it sells and use it to grab the ribbon and hold it while you fiddle with getting the ribbon in the slot. It’s super easy this way. You’ll have it installed in 36 seconds. Try it. (Reverse tweezers…press to release ones)
    Chris - 返信
  20. Nintendo 3DSのWi-Fiアンテナの交換: 手順 20、 1の画像 1
    • デバイス本体からマザーボードアセンブリを取り外します。
    Make sure when putting the motherboard back onto the bottom part of the casing that the antenna wire is where it should be - the first time I put this back together the wire got loose and was smooshed in between the casing and the Y and Power buttons, causing them to be stiff/not work. Using the spudge should help in pushing the wire back into the slots along the inside of the case.
    when reassembling, watch out for the wireless on/off slider - i had started screwing things back in when i realized the slider had slipped to the wrong side, making the slider non functional. by the same token, watch out for the volume slider on the other side.
    meatshaped - 返信
  21. Nintendo 3DSのWi-Fiアンテナの交換, 上部ディスプレイフロントパネル: 手順 21、 1の画像 1
    この手順で使用する道具:
    • 分解作業を続ける前に、ピンセットを使って、ワイヤレス通知LED用の透明プラスチック製ディフューザーを取り外します。この小さなディフューザーは、ひとりでに落下するので床に落ちると探すのが大変です。ご注意ください。
  22. Nintendo 3DSのWi-Fiアンテナの交換: 手順 22、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 22、 2の画像 2
    • 上部ケース底部からWi-Fiアンテナケーブルを巻き戻して外します。
    • フロントパネルを交換するだけであれば、この手順は不要ですが、上部スクリーン、スピーカー、カメラ、Wi-Fiアンテナの交換には必要です。
  23. Nintendo 3DSのWi-Fiアンテナの交換: 手順 23、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 23、 2の画像 2
    • ヘアードライヤーやヒートガンで上部ディスプレイフロントパネル端を温めて、ディスプレイベゼルに留められた接着剤を柔らかくします。
    • プラスチック製開口ツールを使って、フロントパネル端をこじ開け始めます。
    • フロントパネルをこじ開けるのが難しい場合、ヒートガンで作業領域を再度温めてから、こじ開けてください。過剰に力を入れるとフロントパネルが割れる恐れがあります。
    Maybe a dumb question, but how would I go about reattaching the top screen if it's attached to the 3ds by an adhesive? If I have to use more adhesive to put it back on, what would be the recommended kind to do so?
    jgonsoski - 返信
    I have the same question/concern that "jgonsoski" has. Is the adhesive on the front panel still usable after it's pried off the display bezel? Or does it have to be removed? If so, what adhesive can be used or is suitable to adhere back the front panel to the display bezel?
    STZ9 - 返信
    adhesive is definitely reusable. I just completed this step. Please make sure the new display is ready to take the tape as soon as you remove it from the old display.
    Xpider - 返信
    Disclaimer: I replaced my front panel entirely, and threw away the old one.
    If you do not have a replacement front panel, gently removing it (without getting the adhesive oily from your fingers/dusty) and replacing it is an option. The adhesive is incredibly tacky, and while removing the front panel will weaken the adhesive - it will likely be sticky enough to do its job. If not, double-sided tape or small amounts of water based craft glue may help (disclaimer again: I haven't tried these)- do NOT use superglues/liquid cements/epoxies.
    Tai -
  24. Nintendo 3DSのWi-Fiアンテナの交換: 手順 24、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 24、 2の画像 2
    • 続けて、プラスチック製開口ツールを各サイド端にスライドして、フロントパネルの残りの側面をこじ開けます。
    • 温める時間が少なすぎるとフロントパネルを曲げて/割ってしまいます。また、多すぎると下のLCDを融かして、破壊してしまいます。焦らないで作業してください。
    BE VERY CAREFUL NOT TO MELT THE SPEAKERS. This happened to me and now one of the plastic covers for the speakers is melted inside the speaker itself, despite the display cover being undamaged. It is made of a much thinner plastic and i assume it heats up faster.
    Kishin Slayer - 返信
  25. Nintendo 3DSのWi-Fiアンテナの交換: 手順 25、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 25、 2の画像 2
    • 全側面が解放されたら、ディスプレイベゼルから上部ディスプレイフロントパネルを持ち上げます。
  26. Nintendo 3DSのWi-Fiアンテナの交換, リアディスプレイベゼル: 手順 26、 1の画像 1
    • リアディスプレイベゼルをフロントディスプレイベゼルに固定している3.6mmプラスネジを6本外します。
    Some versions have a seventh screw under the right speaker, I almost broke mine because of that
    AD RC - 返信
  27. Nintendo 3DSのWi-Fiアンテナの交換: 手順 27、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 27、 2の画像 2
    • リアディスプレイベゼルを上向きに、ヒンジを自分と反対側を向くようにして、デバイスを裏返します。
    • リアディスプレイベゼル端を自分に最も近くなるように持ち上げ、ヒンジ側に向けて回転させます。
    • 続けて、デバイス本体からリアディスプレイベゼルを持ち上げて、解放します。
    • リアディスプレイベゼルの底部に固定しているクリップがあります。十分な力を入れてクリップを外し、破壊しないようご注意ください。
  28. Nintendo 3DSのWi-Fiアンテナの交換, 上部ディスプレイアセンブリ: 手順 28、 1の画像 1
    • フロントディスプレイベゼルから3D調整スイッチを取り外します。
    • この手順は、解体する手順は不要ですが、スイッチはひとりでに落下する恐れがあります。自分で取り外すことで起こりやすい、紛失の危険性を減らしてください。
    What if I need a new one
    cbryans - 返信
  29. Nintendo 3DSのWi-Fiアンテナの交換: 手順 29、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 29、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 29、 3の画像 3
    • メタル製ヒンジとの接点があるABXYボタンの上のスペースにメタル製プローブを差し込みます。
    • 上部ケースの中央に向けてヒンジを押します。この作業は、かなりの力が必要です。
    • 上部ディスプレイの裏面を見たときのヒンジ位置の作業前と作業後の画像が示されています。
    When reassembling you may find it difficult to get the bar back into the hole in the hinge. A couple of tips:
    * Reassemble it with the clamshell pieces in a ‘closed’ position (same position that you took it apart).
    * The pin/bar may have rotated slightly during disassembly (mine did). It only goes into the hole one way - the hole is actually a slot. If the alignment is off even a couple of degrees it won’t pop back in. If this happens simply lift the edge with the bar up out of the hinge and push the bar so it pops back out (like it was going into the hinge). The take a pair of pliers and gently rotate the bar to fix the alignment, pop the bar back to the ‘unhinged/open’ position, then reassemble.
    Bob Pony - 返信
    This comment saved me after 20 mins of frustration. Also, needle nose pliers work great to rotate the bar to proper position.
    Joe_271 - 返信
  30. Nintendo 3DSのWi-Fiアンテナの交換: 手順 30、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 30、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 30、 3の画像 3
    • 作業を続ける前に、3本のリボンケーブルがどのような位置関係になっているか(ゴールドの接点がどこに面しているか)とどのように重なっているか(どのケーブルがどのケーブルの上にあるか)を確認してください。ケーブルの装着位置と順番を間違えると、短すぎて接続できません。
    • 上部ケースから上部ディスプレイアセンブリをゆっくりと引き離します。
    • 上部ケースのスリットに様々なリボンケーブルが通っていることを確認してください。
    • 上部ケースから上部ディスプレイアセンブリを離します。
  31. Nintendo 3DSのWi-Fiアンテナの交換, スピーカーアセンブリ: 手順 31、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, スピーカーアセンブリ: 手順 31、 2の画像 2
    • 上部ディスプレイベゼル内の穴にスピーカーアセンブリリボンケーブルを注意深く通します。
    • リボンケーブルを収めるために、慎重に(アイスクリームコーンのように)渦巻き状にしなければなりません。ケーブルは、穴より幅広です。
    You may want to use small pieces of scotch tape to reinforce each individual ribbon cable before proceeding, being careful not to cover the gold contacts. The cables can be very brittle and when rolled up tightly they can crack and break like a dry leaf. The tape can be left on the cables after removal and installation.
    Benjificus - 返信
  32. Nintendo 3DSのWi-Fiアンテナの交換: 手順 32、 1の画像 1
    • 右側スピーカーボードを上部ディスプレイベゼルに固定している2.5mmプラスネジを外します。
  33. Nintendo 3DSのWi-Fiアンテナの交換: 手順 33、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 33、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 33、 3の画像 3
    この手順で使用する道具:
    • スパッジャーの平面側先端や指の爪を使って、視差バリアリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • 金属製ピンセットを使って、2本のリボンケーブルの接続を外します。
    does it matter if these cables are not connected?
    nuggets321 - 返信
  34. Nintendo 3DSのWi-Fiアンテナの交換: 手順 34、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 34、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 34、 3の画像 3
    • スパッジャーの平面側先端を使って、上部ディスプレイベゼル内の所定の位置から左右のスピーカーを持ち上げます。
    • スパッジャーの先端を使って、上部ディスプレイベゼルからカメラステータスLEDを持ち上げます。
    I accidentally broke the ribbon cable for the camera status LED, reckon I'll get away with it being broken or will it need replacing?
    Dean Withington - 返信
  35. Nintendo 3DSのWi-Fiアンテナの交換: 手順 35、 1の画像 1
    • ディスプレイアセンブリ本体からスピーカーアセンブリを取り外します。
    Das Flexkabel des Lautsprechers muss nicht entfernt werden. Das macht die Montage hinterher nur schwieriger
    Hardver Doki - 返信
  36. Nintendo 3DSのWi-Fiアンテナの交換, カメラ: 手順 36、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, カメラ: 手順 36、 2の画像 2
    • 上部LCDリボンケーブルとカメラリボンケーブルを一緒に慎重に巻いて、ヒンジの開口部に差し込みます。
    Whoever designed this is a major ****. I eventually found a tear on the new LCD's ribbon upon installing, and I recall having a really hard time twisting the 3 ribbons together and into that tiny hole.
    amat2424 - 返信
    This is the crazy hard part of the process. Be patient and it should eventually work. I found that reassembling but leaving all of the pieces out of the case (screen, camera harness, speaker harness) helped. It’s nearly impossible to do this if the screen is sitting in it’s normal position - the corner of the screen blocks a part of the hole. Assemble it all outside of the case, curl up the harnesses, and then work them through the hole. Once you have that done, then snake the wifi antenna through the hole. And finally place the screen into place (and the speakers/cameras/led). This probably took me an hour to figure out.
    Oh, and once all of that was done *then* I worried about curling things up again and getting that black bushing over the cables. I doubt I could have done it with the bushing in place in the hole.
    Bob Pony - 返信
    I’d recommend watching Daniel-Jay Pascual’s video and giving their method a shot. It did take awhile to get it just right, but I eventually got it to work. It worked best for me when I started twisting right below the contacts. As long as you are patient and don’t rush anything you’ll be fine.
    Michael - 返信
    When I was assembling back, when the time arrived of putting back the ribbon cables, I realized the cables need to be at specific order, otherwise they'll get tangled and will slowly slip away from the connection. I had to redo the entire process and weren't told about it until it was too late.
    Jose Ybarra (EbolaGW) - 返信
  37. Nintendo 3DSのWi-Fiアンテナの交換: 手順 37、 3の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 37、 3の画像 2 Nintendo 3DSのWi-Fiアンテナの交換: 手順 37、 3の画像 3
    この手順で使用する道具:
    • 金属製ピンセットを使って、上部ディスプレイベゼルから黒のメタル製ヒンジリングを取り外します。
    • カメラと上部LCDリボンケーブルを注意深く引っ張って、上部ディスプレイベゼルの穴に通します。
    if you dont remove the ring and pull you will rip the camera
    Tyler Moffitt - 返信
  38. Nintendo 3DSのWi-Fiアンテナの交換: 手順 38、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換: 手順 38、 2の画像 2
    • 上部LCDの裏面からカメラリボンケーブルを剥がします。
    • リボンケーブルは、接着剤でLCDハウジングの裏面に留められています。リボンケーブルを引き裂かないよう慎重に引っ張ってください。
    • カメラリボンケーブルアセンブリを取り外します。
  39. Nintendo 3DSのWi-Fiアンテナの交換, 上部LCD: 手順 39、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, 上部LCD: 手順 39、 2の画像 2
    • 親指を使って、上部ディスプレイベゼルから上部LCDを前面から押し出します。
    • 上部LCDを取り外します。
  40. Nintendo 3DSのWi-Fiアンテナの交換, Wi-Fiアンテナ: 手順 40、 2の画像 1 Nintendo 3DSのWi-Fiアンテナの交換, Wi-Fiアンテナ: 手順 40、 2の画像 2
    • Wi-Fiアンテナケーブルを引っ張って、上部ディスプレイベゼルの穴に通します。
    • 上部ディスプレイベゼルからWi-Fiアンテナケーブルを巻き戻して外します。
  41. Nintendo 3DSのWi-Fiアンテナの交換: 手順 41、 1の画像 1
    • 上部ディスプレイベゼルからWi-Fiアンテナを取り外します。
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
5 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
3人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
152,757 ポイント
127のガイドは作成済み
2 件のコメント
this guide is idiotic, i followed it to the letter and all it did was make me realize that there is a much easier and much safer way of replacing the antenna; steps 1-29 (step 30 if you want to, not necessary though) are fine and right on the money, however pushing the ribbons through makes it way more difficult when you could just remove the antenna board, thred just the wire through leaving the ribbons unchanched, and put in the replacement board and thread the wire through, then reassemble the console. this method almost guarantees that the ribbons wont get scratch and you wont get frustrated.
Andrew Clayton - 返信
this is amazing i will going to follow all steps it seems very difficult before i read this but now this will really helpful and easier than i thought thank you!! Antenna Amplifier
Rachel Gelller - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 180
今までの合計 18,667
