メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ninja Foodi DZ401 Heating Element Replacement
必要な工具と部品
    1. Ninja Foodi DZ401 Heating Element Replacement, Top Cover: 手順 1、 3の画像 1 Ninja Foodi DZ401 Heating Element Replacement, Top Cover: 手順 1、 3の画像 2 Ninja Foodi DZ401 Heating Element Replacement, Top Cover: 手順 1、 3の画像 3
      • Position the air fryer so that the front is facing you and the top is accessible.
      • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
      • Place an opening pick on the left side of the corner to hold the ring away from the cover.
      • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
      • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
      FixBotに聞いてみる
      コメントを追加
    2. Ninja Foodi DZ401 Heating Element Replacement: 手順 2、 1の画像 1
      • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
      • There are three openings on the front, one on each side, and four on the back of the unit.
      • The metal spudger may scratch or damage the cover if care is not taken.
      FixBotに聞いてみる
      コメントを追加
    1. Ninja Foodi DZ401 Heating Element Replacement, Outer Casing: 手順 3、 1の画像 1
      • Rotate the air fryer so that the back of the air fryer is facing down and the base is facing you.
      FixBotに聞いてみる
      コメントを追加
    2. Ninja Foodi DZ401 Heating Element Replacement: 手順 4、 3の画像 1 Ninja Foodi DZ401 Heating Element Replacement: 手順 4、 3の画像 2 Ninja Foodi DZ401 Heating Element Replacement: 手順 4、 3の画像 3
      • Remove the ten 15 mm screws from the bottom of the air fryer using a Phillips #3 screwdriver.
      • Remove the power cord cover.
      • Remove the two 16.7 mm power cord bracket screws using a Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Ninja Foodi DZ401 Heating Element Replacement: 手順 5、 1の画像 1
      • Rotate the air fryer so that the rear fan vents are accessible.
      FixBotに聞いてみる
      コメントを追加
    4. Ninja Foodi DZ401 Heating Element Replacement: 手順 6、 2の画像 1 Ninja Foodi DZ401 Heating Element Replacement: 手順 6、 2の画像 2
      • Remove the four 11.1 mm screws from each vent using a Phillips #1 screwdriver.
      • Remove both vents.
      FixBotに聞いてみる
      コメントを追加
    5. Ninja Foodi DZ401 Heating Element Replacement: 手順 7、 3の画像 1 Ninja Foodi DZ401 Heating Element Replacement: 手順 7、 3の画像 2 Ninja Foodi DZ401 Heating Element Replacement: 手順 7、 3の画像 3
      • Carefully pull the outer casing up from the back.
      • Disconnect the front display cable from the motherboard.
      • Fully remove the outer casing.
      FixBotに聞いてみる
      コメントを追加
    1. Ninja Foodi DZ401 Heating Element Replacement, Heating Element: 手順 8、 1の画像 1
      • Rotate the air fryer so that the front is facing you and the top is accessible.
      FixBotに聞いてみる
      コメントを追加
    2. Ninja Foodi DZ401 Heating Element Replacement: 手順 9、 3の画像 1 Ninja Foodi DZ401 Heating Element Replacement: 手順 9、 3の画像 2 Ninja Foodi DZ401 Heating Element Replacement: 手順 9、 3の画像 3
      • Locate the brown/orange wire bundle at the front of the air fryer and extract it.
      • Locate the white wire bundle at the rear of the air fryer and extract it.
      • Using pliers, uncrimp and remove the plastic wire caps.
      • Carefully separate the wires.
      • The wires may be sharp. Use pliers to increase safety.
      FixBotに聞いてみる
      コメントを追加
    3. Ninja Foodi DZ401 Heating Element Replacement: 手順 10、 2の画像 1 Ninja Foodi DZ401 Heating Element Replacement: 手順 10、 2の画像 2
      • Remove the white wire from the three guiding hooks.
      FixBotに聞いてみる
      コメントを追加
    4. Ninja Foodi DZ401 Heating Element Replacement: 手順 11、 3の画像 1 Ninja Foodi DZ401 Heating Element Replacement: 手順 11、 3の画像 2 Ninja Foodi DZ401 Heating Element Replacement: 手順 11、 3の画像 3
      • Remove the single 10.9 mm screw from the front of the heating element using a Phillips #2 screwdriver.
      • Gently pull down the heating element from the front.
      • The element wires should come out of their respective holes.
      • Unhook the heating element from the rear hook.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
A.J. Brain
メンバー登録日: 10/02/24
615 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-2, Carnegie Fall 2024 Eastern Washington University, Team 1-2, Carnegie Fall 2024人のメンバー
EWU-CARNEGIE-F24S1G2
4 メンバー
66のガイドは作成済み
6件のガイドコメント
is it possible to start at step 11 to lower the heating coil a little bit to get inbehind the coil to really deep clean the top area? No tlooking to detach but clean.
Jacob Feht - 返信 共有
You are welcome to try that. If I remember correctly, it may be difficult to do so because of the awkward angle and wires attached. You may be able to lower it slightly but I am unable to confirm that. It is unfortunately a very frustrating device to take apart as you often have to disassemble the whole device, specifically the outer shell and lower base to get what you need.
Preston Dyess - 返信 共有
Where do you get the replacement heating element from? Is it an aftermarket part or OEM?
Alan Smithee - 返信 共有
Just want to start of by saying thank you for these guides. Very helpful. I just want to add that there is a step missing between Step 5 & 7. Step 5 shows the top cover still on but then in Step 7 it’s off. But step 2 shows how to remove the top cover. Also to take the casing off, you have to remove the 4 screws located underneath the top cover. Took me around 20 mins to work out that to take the outer casing off these 4 screws need to come out first. Couldn’t believe how easy the cover came off after removing the screws. 😂
Mifo J - 返信 共有
Whatever about putting in a new element. Where do you get them from? Anyone know how much they are?
Angelin Susan Perry - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 50
過去 30 日: 310
今までの合計 8,205
