メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D3100 Motherboard Replacement
必要な工具と部品
    1. Nikon D3100 Motherboard Replacement, LCD Screen: 手順 1、 1の画像 1
      • Use a Phillips #00 screwdriver for all of the screws.
      • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon D3100 Motherboard Replacement: 手順 2、 2の画像 1 Nikon D3100 Motherboard Replacement: 手順 2、 2の画像 2
      • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
      • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon D3100 Motherboard Replacement: 手順 3、 1の画像 1
      • Peel back the rubber grip on the right side of the camera using a spudger.
      • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
      • Remove two of the 5mm screws under the rubber grip.
      FixBotに聞いてみる
      コメントを追加
    4. Nikon D3100 Motherboard Replacement: 手順 4、 1の画像 1
      • Remove two of the 4mm screws on the left side of the camera.
      FixBotに聞いてみる
      コメントを追加
    5. Nikon D3100 Motherboard Replacement: 手順 5、 2の画像 1 Nikon D3100 Motherboard Replacement: 手順 5、 2の画像 2
      この手順で使用する道具:
      • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
      • Be careful not to pull the panel out too fast or the ribbon may be damaged.
      • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
      • Separate the back panel from the main body of the camera.
      FixBotに聞いてみる
      コメントを追加
    6. Nikon D3100 Motherboard Replacement: 手順 6、 1の画像 1
      • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
      • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
      FixBotに聞いてみる
      コメントを追加
    7. Nikon D3100 Motherboard Replacement: 手順 7、 1の画像 1
      • Remove the tape covering the ribbons. Be careful not to break the tape.
      FixBotに聞いてみる
      コメントを追加
    8. Nikon D3100 Motherboard Replacement: 手順 8、 1の画像 1
      • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
      FixBotに聞いてみる
      コメントを追加
    9. Nikon D3100 Motherboard Replacement: 手順 9、 1の画像 1
      • Remove the old LCD screen from metal plate.
      FixBotに聞いてみる
      コメントを追加
    1. Nikon D3100 Motherboard Replacement, Motherboard: 手順 10、 2の画像 1 Nikon D3100 Motherboard Replacement, Motherboard: 手順 10、 2の画像 2
      この手順で使用する道具:
      • Use tweezers to gently lift the yellow tape from the back of the camera.
      FixBotに聞いてみる
      コメントを追加
    2. Nikon D3100 Motherboard Replacement: 手順 11、 1の画像 1
      • Use a plastic spudger to remove the 6 ribbons.
      • Be careful not to tear the ribbons.
      FixBotに聞いてみる
      コメントを追加
    3. Nikon D3100 Motherboard Replacement: 手順 12、 2の画像 1 Nikon D3100 Motherboard Replacement: 手順 12、 2の画像 2
      • Remove the plug located on the top-right side of the camera.
      • Remove the plug located on the top-left side of the camera.
      FixBotに聞いてみる
      コメントを追加
    4. Nikon D3100 Motherboard Replacement: 手順 13、 1の画像 1
      • Use a Philips #00 Screwdriver to remove the five 3 mm screws marked in the image.
      FixBotに聞いてみる
      コメントを追加
    5. Nikon D3100 Motherboard Replacement: 手順 14、 2の画像 1 Nikon D3100 Motherboard Replacement: 手順 14、 2の画像 2
      • Gently pull out the side wall of the camera so that the motherboard comes out easier.
      • Do not pull too hard or you will risk breaking the plastic.
      FixBotに聞いてみる
      コメントを追加
    6. Nikon D3100 Motherboard Replacement: 手順 15、 1の画像 1
      • Be careful while lifting the motherboard because there is one more ribbon attached.
      • Gently lift the motherboard to separate it from the back of the camera.
      • Use a plastic spudger to detach the ribbon.
      FixBotに聞いてみる
      コメントを追加
    7. Nikon D3100 Motherboard Replacement: 手順 16、 1の画像 1
      • Replace the motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Jet Mejia
メンバー登録日: 09/26/16
686 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 14-1, Eyestone Fall 2016 USF Tampa, Team 14-1, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G1
3 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 92
今までの合計 6,704
