メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nexus 9 Rear Facing Camera Replacement
必要な工具と部品
  1. Nexus 9 Rear Facing Camera Replacement, Rear Case: 手順 1、 3の画像 1 Nexus 9 Rear Facing Camera Replacement, Rear Case: 手順 1、 3の画像 2 Nexus 9 Rear Facing Camera Replacement, Rear Case: 手順 1、 3の画像 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  2. Nexus 9 Rear Facing Camera Replacement, Battery: 手順 2、 2の画像 1 Nexus 9 Rear Facing Camera Replacement, Battery: 手順 2、 2の画像 2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
    FixBotに聞いてみる
    コメントを追加
  3. Nexus 9 Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  4. Nexus 9 Rear Facing Camera Replacement: 手順 4、 1の画像 1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
    FixBotに聞いてみる
    コメントを追加
  5. Nexus 9 Rear Facing Camera Replacement: 手順 5、 1の画像 1
    • The battery should now lift free of the tablet.
    FixBotに聞いてみる
    コメントを追加
  6. Nexus 9 Rear Facing Camera Replacement, Antenna Board: 手順 6、 2の画像 1 Nexus 9 Rear Facing Camera Replacement, Antenna Board: 手順 6、 2の画像 2
    • This step is not necessary if you have already removed the battery.
    FixBotに聞いてみる
    コメントを追加
  7. Nexus 9 Rear Facing Camera Replacement: 手順 7、 1の画像 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
    FixBotに聞いてみる
    コメントを追加
  8. Nexus 9 Rear Facing Camera Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. Nexus 9 Rear Facing Camera Replacement, Rear Facing Camera: 手順 9、 2の画像 1 Nexus 9 Rear Facing Camera Replacement, Rear Facing Camera: 手順 9、 2の画像 2
    • Remove the three 3mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
    FixBotに聞いてみる
    コメントを追加
  10. Nexus 9 Rear Facing Camera Replacement: 手順 10、 2の画像 1 Nexus 9 Rear Facing Camera Replacement: 手順 10、 2の画像 2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
    FixBotに聞いてみる
    コメントを追加
  11. Nexus 9 Rear Facing Camera Replacement: 手順 11、 2の画像 1 Nexus 9 Rear Facing Camera Replacement: 手順 11、 2の画像 2
    • With both ribbons out of the way, you can now lift the motherboard off of the tablet with your hand.
    • The camera is attached to the back side of the motherboard via a ribbon cable.
    • Use a spudger or your fingernail to disconnect the camera from the motherboard.
    • There is a small board that comes off easily with the camera. It is attached to the camera with a ZIF connector, and will need to be swapped over to the replacement camera.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sergio Vargas
メンバー登録日: 01/22/15
313 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 19-11, Maness Winter 2015 Cal Poly, Team 19-11, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S19G11
5 メンバー
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 29
今までの合計 6,395
