はじめに
If your Nest x Yale Lock is related to any of the issues on the battery section of our troubleshooting page, you will need to replace the batteries inside. Use this guide to replace the batteries properly.
The batteries are located on top of the lock, and those batteries provide power to both the lock and the keypad. Without the batteries, both will not function as they should.
Before beginning this process, be sure that the device is off.
必要な工具と部品
Make sure to insert a thin-metal pin into the hole on top and press it down until you feel the cover is loose and then take it out.
