メインコンテンツにスキップ
Motorola Moto G 1st Generation Battery Replacement
必要な工具と部品
  1. Motorola Moto G 1st Generation Battery Replacement, Removing the Cover: 手順 1、 3の画像 1 Motorola Moto G 1st Generation Battery Replacement, Removing the Cover: 手順 1、 3の画像 2 Motorola Moto G 1st Generation Battery Replacement, Removing the Cover: 手順 1、 3の画像 3
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Motorola Moto G 1st Generation Battery Replacement: 手順 2、 1の画像 1
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
    • In some version of this phone, a microSD memory card can be installed. If so, you must also remove these cards.
    • Be careful as to not damage the microSD memory card. Unlike the SIM card, pushing this in may not spring release, as there may not be an eject mechanism.
    • If there is no spring release eject mechanism, hopefully your microSD card has a ridge/raised edge that you can push on with your fingernail or plastic/rubber tool to push the card out. This may be difficult - be patient and do not use excessive force/sharp tools that could cause permanent damage and permanent loss of data.
  3. Motorola Moto G 1st Generation Battery Replacement, Removing the Back Plate: 手順 3、 3の画像 1 Motorola Moto G 1st Generation Battery Replacement, Removing the Back Plate: 手順 3、 3の画像 2 Motorola Moto G 1st Generation Battery Replacement, Removing the Back Plate: 手順 3、 3の画像 3
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
    Die Schrauben sind Torx T4!
    Armin Jacob - 返信
    To confirm Armin’s comment - yes, the screws are T4 not T5.
    Richard H - 返信
    I used T5 and it worked, but it was a very tight fit. I guess tight fit is better for the screws than loose fit, but still, consider trying a T4 screwdriver.
    Patrick Signoret - 返信
  4. Motorola Moto G 1st Generation Battery Replacement, The Inside of your Phone: 手順 4、 3の画像 1 Motorola Moto G 1st Generation Battery Replacement, The Inside of your Phone: 手順 4、 3の画像 2 Motorola Moto G 1st Generation Battery Replacement, The Inside of your Phone: 手順 4、 3の画像 3
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
    It’s a good idea to make a note now of which way the buttons go back!
    Richard H - 返信
  5. Motorola Moto G 1st Generation Battery Replacement, The Battery: 手順 5、 1の画像 1
    • When you remove the back inner cover, the battery will be exposed on the motherboard. The label is upside down, so do not be alarmed.
    • It is attached by adhesive and connected to the motherboard by an electrical ribbon. So a plastic pry tool will be needed for this task.
  6. Motorola Moto G 1st Generation Battery Replacement, Unplugging the Battery: 手順 6、 1の画像 1
    • The battery is attached to the motherboard via an orange ribbon and a plug.
    • Use a flat pry tool to unplug the ribbon from the motherboard. Place the tool underneath the right edge and push up. The plug should come free with minimal resistance.
    Where do I buy the battery Motorola ED 30 for Moto G.
    My location Noida 201301,uttarpradesh, India.Request Email ddrakheja@yahoo.com
    Dindayal Rakheja - 返信
    My Moto g battery requires change.wish to buy one.Request intimate your store in Noida, India.
    Thanks.
  7. Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: 手順 7、 3の画像 1 Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: 手順 7、 3の画像 2 Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: 手順 7、 3の画像 3
    • The right edge of the battery will give you the most leverage when removing the battery from the motherboard.
    • Use the pry tool to lift the edge of the battery. Remember: the battery is attached using adhesive.
    • You will meet a lot of resistance in this step. If the battery seems like it is pulling too much at the motherboard, try moving the tool along the edges to work the battery free.
    • Try not to rush. It is important that you don't ruin anything in the process of removing the battery. The battery will come free, it will just take some patience and finding the right spot to lift the battery free of the motherboard.
  8. Motorola Moto G 1st Generation Battery Replacement, Replacing the Battery: 手順 8、 1の画像 1
    • Once the battery is removed, you will be able to replace it by fitting the new battery underneath back camera (the raised silver box on the motherboard) and plugging the ribbon in.
    • When putting the new battery in, make sure the blue cover (shown in the top left orange circle) is in place. It is a protector for delicate circuitry, so it is important that the cover is in its place when the battery is put in.
    Great and precise guide!
    Fawad - 返信
    thanks, this was a very good guide and helped me give a new lease of life to an otherwise good phone. My 10yo daughter, who disconnected and reconnected the battery and did most of the screws, says thanks too.
    Tim Richardson - 返信
    The instructions were good. Didn’t take long to do, once I had the right tools (I bought a Torx T5 driver, as the tool included with the aftermarket battery was the wrong size; the seller credited the cost of it back to my purchase). The connector was the *only* other challenge: getting it properly lined up & seated.
    Oh, I didn’t have a spudger handy. I used a plastic knife, worked fine. The adhesive was double-stick tape.
    Phone is charging & rebooting right now. Total cost, $13.52, including tool, tax & shipping.
    Ric Lobosco - 返信
    Where did you buy your battery from for such a cheap price?
    Also, others claim that it’s a T4 Torx screwdriver, not a T5. Did you T5 still work?
    FixWiki -
    The T5 worked for me, though it was a very tight fit.
終わりに
106 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Rebecca Montgomery
メンバー登録日: 09/25/14
3,982 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-6, Brown Fall 2014 USF Tampa, Team 1-6, Brown Fall 2014人のメンバー
USFT-BROWN-F14S1G6
4 メンバー
17のガイドは作成済み
30 件のコメント
Good clear instructions. Thanks.
Motog Steve - 返信
seemed to work for me. fiddly screws though.
Joe Turner - 返信
This shows the second gen moto g but the title is for 3rd gen. Is there a tutorial for the 3rd gen?
wjobrie3 - 返信
This is the 3G version (moto g 2013, the all first version) but not the 3rd version :)
Antoine -
It’s none of those, It’s the original NON-LTE 1st gen, and yes the title says 1st gen
01110011 01101000 01110101 01110100 00100000 01110101 01110000 00100000 01101001 01100100 01101001 01101111 01110100 01110011
Nordii -
Great job. Crystal clear instructions.
stevekoesterer - 返信
The youtube presentation includes mention of the plastic pull tab
which might reduce prying.
And I would've like to have seen {which?} buttons are
liable to fall out ("Take note that once inner back cover is removed the two buttons on the side can easily fall out or be removed.")
But TNX...well done!
jamesT
hastigo - 返信
Thank you so much for the clear instructions and clear pictures. Funny enough, the pictures were good enough and this process easy enough that I didn't need the text. I read them anyway at the end. (I know, I know, bad form. lol)
Matt Sawicki - 返信
One of the metal plates with holes has moved while i was replacing the battery, Is that important?
David Sinapellido - 返信
Awesome instructions!! Thank you!!!
Lorie Bolden - 返信
Haven't tried it yet but am ecstatic that I don't have to buy a whole new phone. Thank you, thank you, THANK YOU!!! Just have to find a plastic pry tool now.
Rhonda Tannehill - 返信
Should the replacement battery have any kind of adhesive to hold it in place like the original?
Chris Caudle - 返信
where the battery for this phone is the date of manufacture? How to find it and read it?
kitachi - 返信
It's a big pain in the ass. Average time to replace the batter is 1 hour? WTF. My old Motorola Atrix 4g takes me 30 seconds total time to replace the battery. One would;d think that newer androids would be easier not more difficult. Should have bought a different phone. I also have trouble with the phone freezing up and may have to reboot it three or four times a day. What a piece of crap.
perkeneff - 返信
Does it matter if I initially didnt re-install the blue cover (rubbery piece) that sits under the battery (to protect the LCD cable underneath) that when putting the battery over it (didnt connect it to motherboard before discovering I forgot to put back the blue cover) it would have damaged the LCD/digitizer in any way? I put my phone back together and when I powered it back on I noticed that there is some distortion on the LCD screen and the touch screen (digitizer) is not working. I'm wondering if just placing the battery over the LCD connector without the blue cover in any way damaged the circuitry, even though the bettery was never connected to the board.
kdrymer - 返信
If there is a higher capacity battery available, like 2500mAh instead of 2070 is it safe to replace
Akrit - 返信
Hey there,
thanks ever so much for this. Saved my ass.
Hardest part was tracking down a battery (same day) - and oddly enough the Torx 5.
Ended up having to by a smart phone tool kit...Oh well...
Thanks again -- and keep that info flowin'!
rupertredd - 返信
when the new battery and tools arrive I will follow this guide.
Tony Kelts - 返信
After an hour or two with a hammer and chisel, 4 ,cans of Guinesss. 10 naughty smokes. and 14 Valium. I decided the best bet
is a visit to my local, friendly, pc shop in the morning, yes folks the old 'uns were a lot easier, Progress.. don't mak me laugh!!
But, sincere thanks to the person who posted the info, I am very grateful; If we ever meet, I will invite you to dine with me, LOL;
Eagle...
Bernard - 返信
I broke the battery connection to the motherboard. The soldering has come out. What do I do? Please help asap :(
Vineet Ashtekar - 返信
Thanks you very much, I followed the steps and I have to admit it is really simple.
mayerly - 返信
Precise and concise guide. Very useful and it only took the forecast 20 minutes! Many thanks.
Christopher Tierney - 返信
I did it used finger nail, it works.
edgardundas - 返信
Instead of the prying to let her use my finger nail and it worked only lost two of the 11 screws,, and it works great.
edgardundas - 返信
Excellent instructions!
Babel 17 - 返信
Thank you it works fine for
Moritz - 返信
Is it necessary to recalibrate the battery after replacement?
Oleksa Stasevych - 返信
Thank you very much! Clear and correct instructions!
Ello Gallo - 返信
Vielen Dank, die Anleitung war super.
Marion Kratel - 返信
Do these instructions work for the Moto G 5.1 phone?
grammygal1018 - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 28
過去 30 日: 92
今までの合計 103,238
