メインコンテンツにスキップ
Motorola Moto E5 Battery Replacement
必要な工具と部品
  1. Motorola Moto E5 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Prepare an iOpener and heat the back of the phone along one edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the back cover to the phone.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough to cut the adhesive. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the internal battery is susceptible to heat damage.
  2. Motorola Moto E5 Battery Replacement: 手順 2、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 2、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 2、 3の画像 3
    • Apply a suction handle to the back cover, near the middle of the edge you heated up.
    • Pull the suction cup with firm, constant pressure to create a slight gap between the phone's frame and the back cover.
    • Insert an opening pick into the gap.
  3. Motorola Moto E5 Battery Replacement: 手順 3、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 3、 2の画像 2
    • Slide the opening pick along the edge of the phone, cutting through the adhesive securing the back cover to the phone's frame.
    • As you move on to cutting the adhesive around the rest of the phone, it may help to leave an opening pick in place here and grab another for the following steps.
  4. Motorola Moto E5 Battery Replacement: 手順 4、 1の画像 1
    • Use the iOpener to heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch.
  5. Motorola Moto E5 Battery Replacement: 手順 5、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 5、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 5、 3の画像 3
    • Continuing sliding the opening pick down and cut the adhesive around the bottom of the phone.
    • If the adhesive is too tough to slice, continue to heat it until it softens enough to slice through it fairly easily.
  6. Motorola Moto E5 Battery Replacement: 手順 6、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 6、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 6、 3の画像 3
    • Use the iOpener to heat the back of the phone along the other edge for about two minutes, or until it's slightly too hot to touch.
    • Continue cutting through the adhesive along the side of the phone.
  7. Motorola Moto E5 Battery Replacement: 手順 7、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 7、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 7、 3の画像 3
    • Use the iOpener to heat the back of the phone along its top edge for about two minutes, or until it's slightly too hot to touch.
    • Continue cutting through the adhesive along the top edge of the phone.
  8. Motorola Moto E5 Battery Replacement: 手順 8、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 8、 2の画像 2
    • There are some areas around the edge that are held down with plastic clips. The opening pick should detach most of the clips. If not, insert an opening tool into the gap and pry the back cover up to release the clips.
  9. Motorola Moto E5 Battery Replacement: 手順 9、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 9、 2の画像 2
    • Once all the adhesive is cut, carefully lift the back cover off the back of the phone.
    • Don't fully remove the back cover yet. The fingerprint sensor cable is still connected to the phone, and it can rip easily with too much tension.
  10. Motorola Moto E5 Battery Replacement: 手順 10、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Remove the following Phillips screws securing the fingerprint sensor cable cover:
    • One 1.6 mm screw.
    • One 3.8 mm screw.
    • Throughout the repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  11. Motorola Moto E5 Battery Replacement: 手順 11、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 11、 2の画像 2
    • Use a pair of tweezers to remove the fingerprint sensor cable cover.
  12. Motorola Moto E5 Battery Replacement: 手順 12、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 12、 2の画像 2
    • Use a spudger to pry up and disconnect the fingerprint sensor cable connector.
  13. Motorola Moto E5 Battery Replacement: 手順 13、 1の画像 1
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
    • Remove the back cover.
    • Since the back cover is held down with clips, replacing the adhesive around the perimeter of the back cover is optional. Replacement adhesive comes in a pre-cut sheet to match the contours of the back cover.
  14. Motorola Moto E5 Battery Replacement: 手順 14、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 14、 2の画像 2
    • Remove the eleven 3.8 mm-long Phillips screws securing the midframe.
    • A couple of screws are hidden under "S" stickers. It may help to remove these stickers with a pair of tweezers before removing the screws.
  15. Motorola Moto E5 Battery Replacement: 手順 15、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 15、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 15、 3の画像 3
    • Insert your fingernail or the flat end of a spudger into the notch at the bottom of the midframe.
    • Pry up with your fingernail or the spudger to loosen the midframe and remove it.
  16. Motorola Moto E5 Battery Replacement: 手順 16、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 16、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the battery connector.
  17. Motorola Moto E5 Battery Replacement: 手順 17、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 17、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 17、 3の画像 3
    • Use a pair of tweezers to peel up the two battery adhesive tabs at the bottom of the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  18. Motorola Moto E5 Battery Replacement: 手順 18、 2の画像 1 Motorola Moto E5 Battery Replacement: 手順 18、 2の画像 2
    • Slowly pull the battery adhesive tabs to release them from the bottom of the battery.
    • Be sure to pull very slowly, giving the strips time to stretch and separate.
    • Pull at about a 45-degree angle to prevent the strips from dragging too much on the battery or the phone's frame.
    • If the adhesive strips break off, move on to the next step for an alternative battery removal method.
  19. Motorola Moto E5 Battery Replacement: 手順 19、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 19、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 19、 3の画像 3
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • If the adhesive strips broke and you can no longer access them, insert a plastic card in between the bottom of the battery and the phone's frame.
    • Carefully push the card down and inward to wedge it underneath the battery and pry it up.
    • Avoid bending the battery while you perform this step. Go slowly and be patient with the remaining adhesive.
  20. Motorola Moto E5 Battery Replacement: 手順 20、 3の画像 1 Motorola Moto E5 Battery Replacement: 手順 20、 3の画像 2 Motorola Moto E5 Battery Replacement: 手順 20、 3の画像 3
    • If you successfully removed the adhesive strips, insert the flat end of a spudger in between the bottom of the battery and the phone's frame.
    • Lift up the battery to free it from its recess and remove it.
  21. Motorola Moto E5 Battery Replacement: 手順 21、 1の画像 1
    • Before installing the new battery, be sure to remove any broken adhesive strips that were left behind.
終わりに
Repair didn’t go as planned? Check out our Motorola Moto E5 Answers community for troubleshooting help.
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Craig Lloyd
メンバー登録日: 02/10/16
35,421 ポイント
82のガイドは作成済み
3 件のコメント
отлично! долго не хотел его делать без инструкции.
Нестор Махно - 返信
For step #14, I had 15 screws on my midframe as it covered the entire bottom of the phone and didn’t taper down like yours did. Otherwise, the guide was great with no surprises, thanks.
Anthony Bybell - 返信
Danke für die gute Anleitung. Zwar mußte ich einiges am Anfang anders machen, da der Akku schon hie Rückwand aufgesprengt hatte. Aber es hat sich gelohnt.
Anzumerken sei nur, das beim Werkzeug eine kleine selbsthaltende Pinzette günstig währe. Ich hatte eine solche in meinem Bestand und die hat mir beim Zusammenbau gut geholfen.
Mal sehen ob das Handy nach dem Akkuschaden wieder voll funktioniert.
Danke allen die so eine gute Beschreibung geliefert haben.
Elektroni - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 70
今までの合計 7,108
